Old 03-12-2019, 04:32 AM
HiLoc HiLoc is offline
Default HDX nightmare
From the time I've moved from HD3 to HDX 1 it getting worst and worst
I'm on PT10 OSX 10.8.5
From a certain point the crash are regular whatever I do.
I open my session and
I miss output (desactivate)
Crash
When I want to import session datas
When I want to edit a plugin
Etc Etc
CAN'T WORK LIKE THAT
[FONT="Comic Sans MS"][B][COLOR="SlateGray"]Mac Pro Dual 6 Core Intel Xeon @ 3.46 GHz, 48Go RAM, OS 10.8.5, HDX Protools HD 10.3.10
1 x HD I/O + 1 x 192
Old 03-12-2019, 08:39 AM
TOM@METRO's Avatar
Default Re: HDX nightmare
Have you looked into the possibility that plug-ins could be the culprit here?
If not, then try moving all but Avid plug-ins from the Plugins folder and see if it helps.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-12-2019, 03:18 PM
You can also try running with Built-In Audio as the playback engine and seeing if you can get crashes to happen there as well, that will help show if HDX (or the HDX side of plugin processing is an issue or not).
There is lots of other standard troubleshooting to do, starting with trashing prefs and testing with a new empty session, start at the "Help Us Help You" up top of each DUC web page. You may have tried all that, but we can't guess.
If you want more help here it would help if you reported the exact AAE error message, or whatever else is happening.
Old 03-13-2019, 08:49 AM
I've re-install PT 10.3.10 "Pro_Tools_10_3_10_Mac_84129" for HDX
Restart PT with the basics plug-ins = OK
Then add one by one until I add Steven Slate VMR.... then crash, after I found earlier version on them site install it = no change = crash
I have a support ticket at Slate but they can't help a lot for the moment
They have the list of all version I've used.
I check the driver version it's "HD_Driver_11_3_1_Mac_84149"
PS: I'm on PT from the Nubus Mac system V3
Old 03-13-2019, 09:07 AM
TOM@METRO's Avatar
I can only speak for our studio, but removing all Slate has helped significantly with stability here.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 03-13-2019, 12:52 PM
Southsidemusic's Avatar
Thats weird ss we use the Everything Bundle on ALL our sessions and the Slate stuff works great here. Yes we are Macs only here. Maybe that is a reason why we afe all good and some windows users I seen have issues ?!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-20-2019, 11:45 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Os 10.8.5
Pts 10.3.10
HD 11 driver?
Old 04-01-2019, 03:39 PM
Chief Technician Chief Technician is offline
Exclamation Re: HDX nightmare
Originally Posted by DetroitT View Post
Os 10.8.5
Pts 10.3.10
HD 11 driver?
Agreed. My memory is that the v10 installer includes the driver. The driver install was separate beginning with v11.
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
More PT 10 nightmare notedmusic Windows 18 05-22-2012 11:04 PM
Nightmare or not ! French links 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-24-2008 03:34 PM
What a nightmare!!! Ronbo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 10-13-2007 04:20 PM
HD Nightmare !! Allan Speers Pro Tools TDM Systems (Mac) 9 08-03-2002 10:00 AM
!!NIGHTMARE!! germ Pro Tools TDM Systems (Mac) 11 05-24-2001 02:37 PM
