Crash Reporter and Crash Issue
I still am having the issue with the Crash Reporter Prompt and PT's 12.0 crashing on start up. I have tried trashing prefs and booting without the effects. The problem persists.Doesn't anyone have advice about this issue? I'm sure I'm not the only one with this problem. I have an I Mac with 32 gigs of ram, just purchased sub for PT's, I use three external drives and have a SSD internal drive. Hope someone can help. I've emailed support and so far no answer.
Re: Crash Reporter and Crash Issue
Hi !
Update ilok manager if needed . Also try unistalling a reinstalling PT .
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Thankyou! I have most recent version of I Lok since I just purchased the Pro tools update. I may re install if I can't find another fix.
Could be a problem with a plugin trying to load. Does it crash during the plugin loading process? If so, look at the last plugin trying to load before it crashes, then temporarily remove it from the plugins folder and see if PT loads.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
No, it crashes after the plugins are loaded. The window appears and I choose my file and after it loads the crash reporter comes up. I can't report anything because the crash reporter freezes.
Could still be a plugin issue. Have you tried opening the session with all plugins disabled?
Yes, and it opens.
Then, assuming it is a plugin issue, it's a matter of figuring out which one is causing the problem thru process of elimination.
Yes, I am aware of this. I tried adding one at a time and PT's opened, but then some time later it did the same thing: crashed on start up. It's strange because it doesn't do it every time, but too many times for comfort. Strange that older versions of the app never crashed on me.
Crash Reporter | priorytools | Pro Tools 11 | 7 | 03-18-2023 08:39 AM |
Crash Reporter and Crash Issue | luci19C | Pro Tools 12 | 0 | 02-14-2019 11:37 AM |
Pro Tools 11 Crash Reporter - send in those crash logs! | Bob Brown | Pro Tools 11 | 37 | 01-29-2015 12:37 PM |
Crash crash crash crash crashhhhh crahshrbnjfgeviufdbldfgvjndgokhng | FuneralMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 27 | 11-16-2009 12:02 AM |
Installed 32track le version, won't run with Reaktor crash crash crash | Christian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-02-2002 11:05 AM |
