Problem with pre/post roll punch-in record
Hi everyone.
I am running PT 9.0.3 on an Intel mac 2 X 2.66 Ghz dual core Xeon machine, 3 gig RAM, Quad core and three Serial ATA drives - 1 TB, 500G and 150 Gig drives. I also have two external 250 Gig firewire drives connected. The mac model is MacPro 1,1 (2006 I think). Interface is an 002. When I try to punch-in with pre-post roll enabled the pre/post roll is ignored!! It's a while since I have used ProTools as I have been working in studios running other apps lately. I was sure I was setting up and enabling the points and range correctly so I fired up LE 7.4cs10 on an old 17" Powerbook connected to a 002 and discovered my memory serves me correctly and the punch-in with pre/post enabled worked fine on this setup. Is there a known problem with pre/post roll using PT 9.0.3? I'm back in my own studio again trying to lay some new originals down when the mood is on me and I have some time! So any help would be appreciated so as I can get on with it before I get called back to work elsewhere again. Thanks, Eugene. Thanks guys |
Re: Problem with pre/post roll punch-in record
I discovered on another post that the Dynamic transport being selected in the options menu is the reason so all ok now.......can get on with my work!!
Thanks all, Eugene. |
Pre-roll/post-roll appears to be broken in PT10 | anodecathode | macOS | 1 | 02-20-2012 01:33 PM |
PT8/7 Pre/Post roll in loop record mode question - is there a bug or is it normal? | bukman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-07-2011 06:07 AM |
Pre Roll/ Post Roll Problem | Edson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-18-2008 05:29 PM |
Record Punch Problem: Hear old take/Record new take | Felix Rost | Pro Tools TDM Systems (Mac) | 5 | 01-04-2008 11:29 AM |
quick punch pre/post record | Mt.Everest | Pro Tools TDM Systems (Mac) | 1 | 07-17-2002 12:28 AM |
