inputs 3 & 4 of my 001 interface stopped working!
All of my inputs work fine, except 3&4 of my 001. Nothing registers when I plug any kind of mic or instrument into it........I have had the system for about 2 years, and have never had a problem until now. Is it possible that I have somehow "blown" the two channels?
Any quick fix ideas? |
Re: inputs 3 & 4 of my 001 interface stopped working!
Is your monitor mode button pushed in?
iMac 27/2.66QC/2x2GB/1TB/4850-512 003r - ProTools LE 8.0.3 |
Yes, and besides, all of my other inputs work fine.
Did you notice a pop or an overload recently that eminated from what was plugged into 3 and 4? Even for a second?
I had a similar problem with 5 and 6 on my 001...pop, and then nothing. Also had mine two years. I had to send it in for repair, and Digi sent me a whole new 001.
One good thing about music: when it hits, you feel no pain. --Bob Marley Rig: MacBook Pro (15,1) 6-Core i7 2.6GHz / 32GB RAM / OS 13.5.2 / PT 2023.9 / Waves Horizon v14 / iZotope Music Production Suite 4.1 / Focusrite Clarett 4pre USB / Apple SSD AP1024M 1 TB (System), Samsung T5 SSD 1 TB (Audio) / Cal-Digit TS3 Plus TB3 Dock / Genelec 1030A Monitors |
If the monitor mode button is pushed in you will not register anything coming in when in the PT session, only in playthrough.
1Ghz Titanium 002r |
If the monitor mode button is in, the only thing that will play through the PT monitor outs is what is plugged into ins 3/4.
It is possible you are experiencing a quality control problem many have had with the 001, poor solder joints that finally failed. Try wiggling the trs connector around with a signal coming it. If the signal cuts in and out, you need to have the solder points for the connector to the PC Board resoldered. If you are a reasonably good solderer, and not squeamish about taking your 001 apart, the DIY. Otherwise, find a local tech shop, or even a tech from a local sound company to do it for you. Have them do all the solder points on all the connectors, not just the ones that are defective. Hope this is helpful. |
Kind of an obvious thing, but did you check under Setups>Hardware>OtherOptions to make sure the inputs for 3&4 are turned up?
Digi001 * Pro Tools LE v5.2beta * Mac G4 733Mhz * 1.5gb RAM 40gb internal HD * Lacie 40gb firewire HD * Radeon 7000 dual-display http://www.erikkarter.batcave.net |
Check and see if inputs 3&4 are even activated in your I/O setup (under your menu Setup/I/O setup.) Click on the input tab and make sure 3&4 are activated. If that doesn't work, you most likely have a hardware prob. [img]images/icons/frown.gif[/img] [img]images/icons/confused.gif[/img]
Jayman #9 |
What are you plugging in to them? Mic's won't work in 3-8 with out a pre amp.you should try a drum machine or sound module direct,if that does not work,then check your patching,cords etc.
Ray |
Just in case: if you're trying to use monitor mode to listen to what's plugged in 3 and 4 without launching PT, remember that monitor mode does not work with the headphone, so you won't hear anything anyway.
Mbox Mini 3G Interface Stopped Working 8 Months After Purchase | 1cannoyed | FireWire & USB Audio Interfaces (Win) | 3 | 10-24-2013 11:30 PM |
Digi 003 Inputs stopped working | babygoboom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-28-2013 06:55 AM |
PT has stopped working??? | digifriend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 10-06-2008 12:12 PM |
Digi 192 inputs stopped working | KenSluiter | Pro Tools TDM Systems (Mac) | 3 | 05-21-2007 04:46 PM |
Inputs on the back of my 001 have stopped working | TNVern | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-12-2005 01:56 PM |
