#31
Re: EuControl v3.7.0/ Pro Tools | Control on iPad Pro doesn't work...
Are you sure its in the right hand list in EuControl ? Can you do a screen grab ?
#32
Issues connecting PT Control as well. I have tried 2 different qualified iPads (both running v3.7 of Control app and 1 running iOS 10.3.1 the other running iOS 11.2.5). EuControl is v3.7 and can see either iPad and gives info when clicking on info button. So it seems PT Control and EuControl are talking.
"Not connected" in Red on top of iPad For PT, I am running v2018.1 on a MBP with OS 10.12.6 and yes "Enable Econ" is checked under peripherals. I am on a 5GHz network as well. Is there an issue with v2018.1 and PT Control? |
#33
Have you dragged the Control App across into the right hand column in EuControl ? Can you send a screen grab ?
#34
Screen grab
#35
Thanks that looks good, can you post the Workstation tab too ?
#36
Also try this. Swipe 4 fingers up on the iPad and force quite the Control App (swipe it off the screen). Then start it up again.
#37
I forced quit the app (tried this several times previously) and still nothing. Theres nothing in either column of the workstation tab listed. Ive tried enabling and disabling this tab. Makes no difference
#38
screen grab workstation
#39
take 2
#40
Dont check the Enable External WS that's for a 2nd machine. The issue must be that your Workstation is not showing in the workstation list.
Can you try this.
If this doesnt work I would uninstall using the uninstaller in the Euphonix folder in Applications and re install. |
BUG: Eucontrol 3.6.1 assignable knob doesn't work with application lock | Raphie | Artist Series | 1 | 09-25-2017 04:18 PM |
Pro tools control iPad Pro | Sir_MixAlot | Avid S1, S3, Dock and Control App | 7 | 08-21-2017 09:20 AM |
EuControl/Workstation 3.3 & Pro Tools | Control iPad app now available! | Kyle Splittgerber | Avid S1, S3, Dock and Control App | 0 | 08-06-2015 02:59 PM |
Can I control Pro Tools with an Ipad | south89 | macOS | 4 | 04-05-2013 09:36 AM |
