Old 07-21-2002, 07:05 AM
jbraly jbraly is offline
Default clipping and compression of vocals
Has anyone found a way to limit the level of vocals at the time they are being recorded? I often clip when I record a vocal, especially if the singer is not good with microphone technique.
I had the idea that you could put the RTAS compressor in Pro Tools Free into the channel and it would work while you were recording. Say, set the ration to 4 to 1 or so, attack at 11 milliseconds, release at 50 ms. Then, if the singer shouts, the compressor would knock it down BEFORE it clipped and you would have a no-clip recording. Alas, the compressor does not seem to work that way -- before the fact.
Perhaps I am setting it up wrong. Anyone have some advice? Do I need an outboard compressor to accomplish this?
Thanks,
Jim
G5 -- dual 2 gHz -- 2 gigs ram -- OS 10.4.6
Old 07-21-2002, 10:45 AM
JHarris JHarris is offline
Default Re: clipping and compression of vocals
Hi Jim
to compress a vocal while tracking, you need to create an aux track for your input, and bus the output of your aux track to the input of the audio track you're recording to. Insert a compressor, (or other signal processing) on one of the aux track's inserts. Record enable your audio track, and you should see level going to both channels at this point. Now when you record, your input is routed through the compressor (or other processor) on the aux channel before going to 'tape'.
John Harris
43 Algoma Crescent
Hamilton, ON L9C 1S5
(905) 385-2979
[email protected]
Old 07-21-2002, 02:43 PM
M.Brane M.Brane is offline
John is correct. You need to run the compressor before your input otherwise your still going to be clipping your hardware.
Old 07-21-2002, 04:54 PM
audiaudio audiaudio is offline
Two suggestions:
1. Use a hardware compressor before the A|D converter. The Avalon 737 is a commonly used mic pre/eq/compressor in one box.
2. Lower the record level. At 24-bit, there's no reason to record peaks anywhere near digital maximum. The mix bus will also benefit from lower record levels.
 iMac i7 2020 Monterey 16GB HD Native Thunderbolt
Old 07-21-2002, 05:39 PM
John Link John Link is offline
What do you mean by this?
John Link
Old 07-21-2002, 11:51 PM
I'd like to know how to record into PTF at 24bit. [img]images/icons/confused.gif[/img]
Old 07-22-2002, 12:06 AM
What John Harris suggests may compress the vocal but it will not avoid digital clipping, since the signal is already too strong by the time Pro Tools gets it. The compressor has to be further back in the signal path.
I raised a similar question recently and you might find the discussion useful: http://duc.digidesign.com/cgi-bin/ub...;f=35;t=000940
John Link
Old 07-22-2002, 06:05 AM
Wouldn't we all!
John Link
Old 07-24-2002, 04:16 AM
Any of these audio interfaces will enable 24-bit recording into PT Free:
Digigram VX Pocket (PCMCIA)
Edirol UA-5 (USB)
Ego Systems U2A (USB)
eMagic EMI 2|6 (USB)
Sound Devices USBPre (USB)
Tascam US-428 (USB)
Old 07-24-2002, 07:30 AM
audioaudio, have YOU recorded into PTF at 24 bits? My understanding is that PTF takes its sound input only from the Mac Sound Manager, which works only at 16 bits, making recording into PTF at 24 impossible.
John Link
HTML code is On
compression several vocals at once?? muse6638 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-09-2005 06:27 PM
Tracking vocals with or without EQ/Compression oedipus_complex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-28-2004 06:00 PM
Compression, clipping and the red LED davetron5000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 03-16-2004 05:13 PM
compression w/ vocals JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 02-19-2004 11:35 AM
vocals, compression, C1 and the PENTA.... pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-25-2002 07:42 AM
