Old 04-13-2019, 02:36 AM
matthewmkb matthewmkb is offline
Default Dynamic Playback goes silent when playing before/after the timeline selection
Hi, I use dynamic playback quite frequently and always wanted to ask about this issue as I have been having it on and off since probably 12.7 which was my first PT version. Often times I will want to let's say start the playback at bar 4 and perhaps have it looped around bars 12-16. It will probably work for a while and then it will go silent. I will start the playback on bar 4 again, no sound and then it's back when the loop begins. Other times it will play for a few seconds, then goes silent and comes back when the loop begins. It also happens after the timeline selection and then I will only get sound from the loop range and nothing before/after. Is there something I am not realizing here that makes me encounter this issue? Obviously if I remove the timeline selection and just play the track from any place, it will work as expected. CPU, SSD and RAM usage is very low, no problem here. Thanks.
Playback won't start at Timeline Selection Point museman Pro Tools 10 16 03-12-2024 11:45 AM
Timeline selection while playing forces playhead jump geelo Pro Tools 9 5 02-19-2018 02:45 AM
Playing back part of a selection without affecting timeline/selection jschmidtiii macOS 2 05-11-2013 01:05 PM
Playback stops at end of timeline selection? Blank Frank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-12-2009 12:36 PM
silent psu selection 1Nation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-07-2003 12:14 AM
