Old 08-21-2010, 07:33 PM
beasleymusic beasleymusic is offline
Default Signal from Profire 2626 to pro tools isn't working properly
I just recently purchased a profire 2626 and pro tools m-powered. It was working great and had no problems until I need inputs 5-8. I first thought, maybe those inputs are messed up, but I'm getting a signal from them into the computer. When I open up tracks in pro tools, inputs 5-8 do not record any audio. But like I said, they work because I'm getting a signal into the computer, pro tools just won't record any audio being played from inputs 5-8. Help me please
Thanks,
Will
Old 08-21-2010, 07:44 PM
DigiTechSupt's Avatar
Default Re: Signal from Profire 2626 to pro tools isn't working properly
Have you checked Setups>IO to make sure those paths are showing up properly and mapped to the correct inputs from the 2626?
You may want to save your current IO Setup, then delete all the paths on the left in the Input tab, then click on the 'Default' button in the lower right. That should assign all inputs properly.
Let us know if that works for you.
Avid Audio Tech Support
Support FAQ
Old 08-21-2010, 08:09 PM
Yes that worked! Thanks so much!
Profire 2626 + Pro Tools rapheal robinson Pro Tools 9 4 09-24-2013 08:13 PM
Profire 2626 working with PT 11? necjamc Pro Tools 11 8 06-26-2013 09:50 AM
Profire 2626 + Pro Tools Salivan Pro Tools M-Powered (Win) 3 07-30-2011 11:05 AM
V-Verb Pro + ProFire 2626 + Pro Tools = HELP ME!!! cueball73 Pro Tools M-Powered (Mac) 2 12-03-2010 09:18 AM
pro tools Le 8 With Profire 2626 yungvilleproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-12-2009 08:15 AM
