Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-28-2007, 08:46 PM
Kon Alexiou Kon Alexiou is offline
Default PT Drum ideas and suggestions
I can play basic drums but the neighbours won't be happy if I start recording an acoustic kit...I've considered a Roland electric set but I believe there are other alternatives....
I've heard of drummers/producers using programs such as BFD or Sampletank to manually create drum parts bit by bit i.e. kick first, followed by snare etc..I've tried this and it's not bad...I've also read a number of people actually overdub a realy hi-hit so as to add more realism to the drums...
I'm loathed to learn the ins and outs of BFD because I can see programing fills/crashes etc...take time.
To all of you drummers or PT users who have good drum ideas what are you doing? What works? What do you think of using a real hit to add that extra sense of reality?
Thanks.
Kon
Old 04-29-2007, 12:06 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: PT Drum ideas and suggestions
Get a cheaper electric kit that has MIDI output. Play your tracks on the kit and record MIDI information instead of the audio. Once you have the MIDI recorded, send that through BFD, tweak as needed.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 04-29-2007, 11:11 AM
Naagzh Naagzh is offline
I have a Roland SPD-S (which has MIDI I/O), to which I've connected a bass drum trigger (w/pedal) and hi-hat trigger pedal, creating a make-shift e-kit for quick demos. The velocity information is okay (you'll have to tweak it) and the pads and external triggers can be routed to separate MIDI channels. So you don't really even NEED an entire electronic kit these days. Short of the newer (and quite expensive) V-Drums, I don't think there's an electronic kit worth the money, especially when the SPD-S and pedals take up so little room.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 05-01-2007, 05:32 AM
Thanks everyone I'll look into these ideas.
drum miking ideas for >this< kit? eric22rr The Drum Room 15 07-01-2011 11:39 PM
Drum Track Ideas Kon Alexiou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-02-2007 01:54 PM
Drum track ideas and suggestions Kon Alexiou Tips & Tricks 4 04-30-2007 09:45 AM
Drum Software Ideas? 100grit Tips & Tricks 10 12-17-2005 11:05 PM
what do i do for drum tracks? any ideas? thumbolt68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-22-2000 10:29 AM
