Transferring
I'm having trouble transferring a session from a TDM rig to a 002; and then to MBOX2 LE. Please help cause I have read the manual pertaining to this and I cant figure it out. Thanks
Re: Transferring
Well, the only problem I can see, is if your goign from MAC to PC, and the MA sessions was using SDII files.
Do a "save session copy in" and selct BWAV as the file format and make sure "pc compatible" i selcted also. |
Re: Transferring
Mac platform. My main problems are what preferences are best to use, what settings to use and anything else you can think of. Usually going from film oriented to video on the TDM. Then trying to open it up on LE 002. Some tracks come inactive and other problems. Im sure its easy I just cant figure it out thanks again.
Re: Transferring
Well, lE has no surround, and you have track/voice limitations in LE.
So, maybe you're runnign otu of tracks, and/or you have created surroudn tracks in TDM that aren't translating. |
Re: Transferring
Yes, and when he says "aren't translating", he means "will NOT be imported/included". Anything that has anything to do with a track or path of 3 channels or more will simply be eliminated by LE.
All those Warning messages you get when you try to open the session, although often are the "yeah, yeah, whatever, hit OK" variety actually become critical in this case. Good luck! |
Re: Transferring
Thank You
Re: Transferring
Thanks again
Transferring PT to a new Mac | DrDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-21-2011 05:48 AM |
Transferring between 24 bit and 16 bit | lew742man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-06-2009 02:08 PM |
Transferring the 001 from Mac to PC | SuprSpy79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-09-2005 05:43 AM |
Transferring wav from pc to mac | Ben Jenssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-24-2002 09:11 AM |
Transferring WIN to MAC | jpd52 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 06-20-2002 12:07 AM |
