Old 09-09-2018, 09:08 PM
Zak7 Zak7 is offline
Default is there is a shortcut to make ALL the tracks always a specific height?
a shortcut to make them all Small o maybe Medium or large, but always that shortcut makes them all the tracks that specific Height?
Old 09-09-2018, 10:29 PM
BScout BScout is offline
Default Re: is there is a shortcut to make ALL the tracks always a specific height?
Hold Option when clicking the track size. It changes all tracks to whatever height you select.
Holding Option when changing things (for most things) applies it to all. Holding Option + Shift when changing things (for most things) applies it to all selected. This is a consistent thing for the Pro Tools environment (Like if you want to see all pan automation for your tracks or solo, mute, or input enable; same modifiers held and then change one of the tracks)
(option is the Mac modifier key, forget what it is on Windows if you need that)
Old 09-10-2018, 06:44 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
You can use a marker or window config.
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 09-10-2018, 03:33 PM
Thanks for the replies.
Yes, but the thing is that any of those shortcuts are relative to the actual size of each track.
what I mean is that regardless the amount of tracks and the size of each track, I wonder if there is a shortcut track that ALWAYS make all tracks the same size! a absolute track size always like for ex always making all track "X" size
Old 09-10-2018, 03:38 PM
amagras amagras is offline
Hold alt in the edit window, grab between two track heads and move the mouse up and down.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 09-10-2018, 05:28 PM
jeffro's Avatar
jeffro jeffro is offline
Have you tried using a Memory Location with just Track Heights enabled (and Time Properties set to None)?
File Type: jpg Screen Shot 2018-09-11 at 7.54.46 AM.jpg (23.1 KB, 0 views)
linkedin
Old 09-11-2018, 05:37 AM
I don't know how to do it with Memory Locations but I've been using Window Configurations and it seems like it could be a good idea for this as well.
amagrasmusic.com
Old 09-11-2018, 10:24 AM
Then i'd use a keyboard maestro macro to trigger keyboard shortcuts to resize all tracks to the smallest size and then resize them all back up to whichever size you need.
Ben Rubin
benrubin.com
Old 09-11-2018, 12:41 PM
No. It's not.
Option and then changing the track size is an absolute adjustment. Everything goes to the size selected. This goes to selecting a size (not incrementing/decreasing sizes). So selecting "small" makes everything small.
Track Height Shortcut Ken Skoglund macOS 0 03-07-2018 06:16 AM
Track height shortcut harrynilsson macOS 13 11-16-2016 03:06 AM
Track Height Shortcut broken cowrange 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-04-2012 11:01 AM
shortcut for multi-track height in 7.1? Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-17-2006 12:53 PM
Shortcut to reduce/increase windows height? Enrico Donner ProControl, Control|24, Command|8 2 05-21-2001 04:21 PM
