Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 11-30-2016, 12:57 PM
Yamorama Yamorama is offline
Default Acquired a Xenyx 802. Where to Use in Setup?
A friend of mine just got rid of a Xenyx 802 mixer, only missing the power supply. I grabbed in case I want to use it in the future.
My current setup is as follows:
Guitar lined-in to Eleven Rack
Eleven Rack output to 2 monitors
Eleven Rack as playback engine for Pro Tools 11, hooked up to Mac Mini via USB
USB Midi Keyboard also hooked up to Mac Mini
I was curious if I wanted to mess with this new piece of equipment where it could fit in my setup? I have no cables with it at the moment. I understand it could be useful if I get a microphone in the future for vocals? Can it be used in conjunction with the eleven rack?
Thanks!
Yam
Old 12-02-2016, 11:33 AM
MSFilmScorer5 MSFilmScorer5 is offline
Default Re: Acquired a Xenyx 802. Where to Use in Setup?
What version of PT are you running?
Chances are that'll be a negative on the 802 unless you plan on using it to monitor but the Eleven Rack has outputs. If you're looking for a control surface then the BCF2000 would be an affordable option. If you really need the inputs you should look for a control surface that supports spdif for the Eleven Rack.
Pro Tools 10 with Behringer Xenyx Mixer vw45 Pro Tools 10 6 09-28-2016 11:52 AM
How do you install xenyx 802 usb interface?? jessicajjackson Pro Tools 12 3 09-26-2016 02:27 PM
Will Pro Tools work with my Xenyx Mixer? tunaman14 ProControl, Control|24, Command|8 3 08-14-2012 06:20 AM
behringer xenyx usb mixers robertcici ProControl, Control|24, Command|8 2 11-11-2010 06:55 PM
DigiMidiService can't be acquired ? Matthai 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-12-2007 06:57 PM
