Old 05-06-2009, 07:37 PM
Roper Band Roper Band is offline
Default Should The Mbox 2 Pro Be Unplugged After Sessions?
If I put my computer to sleep, should I unplug the firewire Mbox 2 every night?
http://RoperBand.com
MBox 2 Pro/Mac Mini, 2.0GHz Intel Core 2 Duo, 4 GB Ram
Old 05-07-2009, 02:33 AM
Delso Delso is offline
Default Re: Should The Mbox 2 Pro Be Unplugged After Sessions?
I always shut down in sequence - powered monitors, Pro Tools, computer, mixer, external hard drive, MIDI controllers - then turn off all the power.
Next day, I do the reverse to begin proceedings. Never had a problem - everything recognised and working.
PTLE 7.4, Mbox 2 Factory
iMac G5 iSight,OS X 5.6
WD My Book 250Gb Firewire drive
Roland RD300s electric piano
Toontracks dfh EZ drummer
Old 05-07-2009, 03:29 AM
chrisdee's Avatar
chrisdee chrisdee is offline
You don't have to disconnect the Mbox2 Pro. It gets the power from your computer via the firewire cable. If you power down your computer the Mbox2 Pro loose it's power anyway, so disconnecting it is redundant.
Some people even pull out the power plug from the socket to all their gear incase of overload in the power grid etc. Other say powering up/down your computer/gear all the time shortens the lifespan.
Nothing lasts forever
Old 05-07-2009, 07:36 AM
I've been putting my Mac Mini to sleep every night (instead of shutting it down), and the light on the pro keeps flashing. I guess I'll continue to unplug the FireWire cable so I don't go insane. Does it matter if the light is flashing? Should I keep it plugged into the wall as well?
Mbox 3 high frequency noise disappears when usb-cable is unplugged and reconnected nickmadsen FireWire and USB Audio Interfaces (Win) 5 02-23-2014 09:25 AM
can Mbox Pro 3 be hot swapped / hot plugged / hot unplugged? marcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-20-2011 05:11 PM
Computer won't hibernate unless MBox is unplugged emzine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-11-2005 10:29 AM
Can the 001 be unplugged??? Angus202 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-21-2003 10:29 PM
Mbox unplugged? Kodiak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2003 06:54 PM
