Old 02-15-2009, 12:49 PM
grubbgto grubbgto is offline
Default Re: High-Pitched whine from MBox2 1/4" outs
Originally Posted by jimst57 View Post
I think that may be because several things can cause hum/noise/whine problems, and different people find different solutions.
What solved it for me was using balanced cables from the Mbox2 outputs to my mixer. The whine is compleatly gone. If I put back the unbalanced cables, it comes back.
i had the same problem years back with the mbox before switching to the 002.
i bought balanced cables, and the 'whine' was gone immediately. it may not be an issue with your mbox/protools as much as it is an issue with your monitors, they are the ones that may want/need the balanced cables. do that first (it's simple and cheap) and you'll probably be okay. if not, you prolly have deeper issues.
Old 02-15-2009, 02:25 PM
jimst57 jimst57 is offline
Originally Posted by djgizmo View Post
How do you use balanced cables when the Mbox2 only has unbalanced outputs?
I have the same issue and I'm wondering how I can resolved it. Ground lifting didn't seem to work for me.
Here's a quote from the Mbox 2 manual:
Mon Out (Monitor Output)
These outputs support balanced TRS, or unbalanced
TS, 1/4-inch connections. To monitor
your mix, these outputs can be connected to a
mixing board, directly to a monitoring system
such as a stereo power amp, or another stereo
destination.
I bought some inexpensive TRS cables and the whine/hum was gone.
Old 08-26-2010, 11:08 AM
The Mink The Mink is offline
My brand-new Mbox 2 Pro (Firewire) is also doing this - but only on the right output. If I plug the same speaker into the left output of the M2Pro, it's dead quiet.
I did all this:
(1.) Using good, balanced Mogami TRS-XLR cables
(2.) Tried another cable anyway, whine is still there
(2.) Tried ground lift, didn't work
(3.) Tried another computer, just to see - still there
Other notes:
(1.) Noise momentarily goes away when I make a change, like swapping out a Firewire cable, then comes back.
(2.) Noise goes away when speaker is unplugged from M2Pro.
(3.) Noise is still there with Firewire unplugged - just M2Pro power cable and speaker plugged in.
(4.) Noise goes away if computer is shut down (with Firewire connected).
(5.) It only does it on the right output!
This is driving me WILD. I hope something works...
iMac 2.8 GHz Intel Core Duo, 4G memory
OSX 10.6.8
PTLE 9.0.5, Mbox 2 Pro
Dynaudios
Organic French Roast
Old 12-07-2010, 09:52 PM
ricardex ricardex is offline
before buying anything try this:
I put one in my mixer's (mackie 1604) power chord, and the noise disappeared just like magic...
Old 06-13-2011, 09:31 AM
Delso Delso is offline
+1
After reading this, I bought some balanced TRS cables to connect my MBox2 to my KRK Rokit powered monitors. As I got behind one of the monitors to make the connection, I spotted the word "Balanced" printed above the input on the back.
Doh!
Whine gone.
PTLE 7.4, Mbox 2 Factory
iMac G5 iSight,OS X 5.6
WD My Book 250Gb Firewire drive
Roland RD300s electric piano
Toontracks dfh EZ drummer
Old 01-16-2012, 07:58 PM
MMorrison MMorrison is offline
Before you buy a Cheater Cable!!!
I did some research after reading all the posts in the thread and found numerous warnings that using cheater cables can electrocute (and kill) you if not used properly and, according to the articles I read, it has happened to a number of musicians trying to solve this very problem. If the ground isn't secured properly (or at all), it can be lethal.
If you're simply plugging in, you're not installing it properly.
Read more here -> http://en.wikipedia.org/wiki/Cheater_plug
From what I've read, it is recommended to use an Isolation Transformer which will allow you to do the same thing safely -> http://en.wikipedia.org/wiki/Isolation_transformer
After a bunch of testing, asking others, reading and thinking I had a ground loop problem in my house, I found that my high-pitched whine is likely coming from a slightly loose ground prong in the power input of the mixer I had connected to my MBox (though it could be something more internal too). Time for the repair shop.
Cheers
Old 11-02-2016, 09:24 PM
lezman lezman is offline
Hi, I had the same problem. I solved it using Balanced TRS cables for all the inputs and outputs!
High-pitched whine in right speaker! The Mink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-23-2012 11:28 AM
High pitched whine GlenHarness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-24-2006 05:38 PM
HPF = high pitched whine Chris Coleman Pro Tools TDM Systems (Mac) 4 02-23-2006 09:53 AM
mBox and PT 7= High Pitched Whine Dr.Quest 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-24-2005 10:20 PM
high pitched whine clay19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-08-2004 01:48 PM
