Old 12-11-2008, 11:27 AM
dubbydougie dubbydougie is offline
Default Problem bouncing multichannel files - format changes
Hi all,
so I'm bouncing 4 channel quad files from the "quad" output (I/O is set correctly). Bounce settings are AIFF, 48/16, interleaved.
If I reimport the bounced file into the session, it shows up as LCRS. Why? Is there a default importing scheme that automatically defaults a 4-channel import to LCRS, or is it encoded as LCRS during the bounce out (which wouldn't make sense as it's originating at the quad output)?
If I change the bounce settings to 'multiple mono', the resulting 4 files are correctly labeled L/R/Ls/Rs and pro tools imports and combines them correctly. However, I don't want multiple mono, I want a single interleaved quad file.
Any ideas?
Old 12-11-2008, 01:27 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Problem bouncing multichannel files - format changes
Originally Posted by dubbydougie View Post
Hi all,
Any ideas?
Look at the i/o setup under the output page and there's a menu for default output order, see if that helps!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-05-2011, 12:08 PM
Helge Schwarz's Avatar
Helge Schwarz Helge Schwarz is offline
Default pt 9.0.1 still imports interleaved QUAD as LCRS
How can i use QUAD-atmos (L/R/Ls/Rs) without naming trouble ?
ProTools 9.0.1 still imports INTERLEAVED Quad to QUAD-tracks as L/C/R/S.
SFX-management in SPLIT-format is no option (preview, metadata, ..)
Bugfix appreciated ..
pt12.6hdx, mp4.1, 5xCd30'', 192io, pre, syncHd, mojoSdi, Artist2mix1tranport, hui
iZotope Denoise and Multichannel files thecrew Post - Surround - Video 2 02-22-2013 09:52 PM
Export Multichannel Interleved Files - Major Bug in PT10 evs Post - Surround - Video 40 08-18-2012 06:49 PM
OMG, PT cannot export multichannel files? cebolao Post - Surround - Video 7 06-04-2011 01:54 PM
problem bouncing to disk in AIFF format moon1pulse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-24-2006 04:04 PM
problem with bouncing to wav format Carnavos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-23-2006 04:09 PM
