Old 01-23-2006, 02:01 PM
Carnavos Carnavos is offline
Default problem with bouncing to wav format
hello everyone. when i try to bounce a song to wav format it doesnt seem to work. i specify a location and pro tools goes through the bounce process (plays through the song), but then doesnt give the loading thing to say its converting the files. weve tried uninstalling the program but that doesnt seem to work. any one else experienced this problem? thanks in advance
Old 01-23-2006, 03:23 PM
LSW LSW is offline
Default Re: problem with bouncing to wav format
I take it you selected the "Convert after bounce.." option? I would try it both ways to see if it makes any difference.
The only trouble I've had personally creating the wav was a too slow hard drive, but it did produce an error.
Old 01-23-2006, 03:24 PM
lemix's Avatar
lemix lemix is offline
Carnavos,
You'll need to be more specific about the process..
Are you getting error messages ?
What version of LE ?
Did you specify a "convert" process ?
Where did you direct the BTD to go ? Did you search for the file ?
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 01-23-2006, 03:59 PM
in response to the questions above:
there were no error messages
pro tools LE version 6.7
i tried both during and after bounce conversions
i directed the bounce to my normal folder where i do that and it didnt show up. i searched other places too, but to no avail.
thanks
Old 01-23-2006, 04:09 PM
lemix's Avatar
OK,
what file format are you bouncing to ?
Have you tried to stay with the session's attributes and "import after bounce "//going to the same session's audio folder ?
If it shows up there ( region list ) you can export to the desired location/format again.
Try that, see if it works.
good luck,
cheers,
Andrew
Problem bouncing multichannel files - format changes dubbydougie Pro Tools TDM Systems (Mac) 2 03-05-2011 12:08 PM
problem bouncing to disk in AIFF format moon1pulse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-24-2006 04:04 PM
Bouncing down audio for a CD:which is right format nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-08-2005 12:14 AM
Best Format for Bouncing? Cavet Your Eruptor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-21-2005 12:02 AM
Bouncing to .wav format problems jaczaj Pro Tools TDM Systems (Mac) 2 09-08-2000 01:27 PM
