Waves install
Greetings!
First post! It's a question, and apparently a stupid one since a search of 'answerbase' and DUC failed to reveal results. Please bear with me. I recently up/cross graded from digi 001 Factory/PC to 002/Mac. Few hiccups, but mostly pleasurable. Anyway I got my waves upgrade installed and authorized, however the waves plugs don't appear in my Protools session. Do I have to place the (waves) folder(s) in a certain location? Do I have to 'connect' in Protools? Could iLok be an issue? I have the original I received with my '001 Factory' installed, and I do get occasional messages that I have an unsupported USB device. Not sure whether iLok is working for or against me at this point. Anyway, seems like the Waves install/upgrade should have happened automatically. Can't fathom how I might have screwed it up. Looks like everything is there. .. Any advice/input appreciated. Thanks, and great to be here. Digi 002 Pro Tools LE Ver. 6.1 Bundle 2.0 (Amplitube, Sampletank, D-fi, Maxim) MAC G4 DP 1.2 768 Meg Ram 80 Gig system drive 120 Gig audio drive Midisport 2X2 USB |
Re: Waves install
This might be your problem. THe waves version you have is old and will not work on OSX. If so, you will need to negotiate with THEM about upgrading, but will it will likely cost you $$. Hope that helps.
pwat Keep Making the MUSIC |
Re: Waves install
Thanks. I believe I have the latest version. Was allowed to upgrade at waves.com since I had bought my 001 w/in the last year. Did the challenge, response, authorized etc.
BTW apologize for the itchy trigger finger (two identical posts). I wanted to do some editing and didn't realize I had passed the point of no return...first time and all..:-] Thanks |
Re: Waves install
You need to make sure the Waveshell-DAE file is in your plug-ins folder. It should have been installed there when you ran the Waves installer. You'll also want to go back to the waves site and download WaveShell-DAE 4.0.1_X - the new 4.0.1 version fixes some problems with random noises generated in ProTools. Replace the original WaveShell in your plug-ins folder with the new one.
If you moved your waves plug-ins folder since you ran the installer, ProTools will prompt you to locate the folder during launch. If you're still having problems, contact waves support through their website. |
Re: Waves install
Thanks. Much obliged. I put a help request into waves. Will check the other right now.
Cheers |
Re: Waves install
I down loaded the latest DAE from Waves (4.0.1_X). I tried placing it and/or DAE 4.0_9 in every folder from the protools root, down into the plug in alias folder. Still no Waves.
Side note, 'Waves' hasn't responded to my support request yet either. Any other thoughts? Thanks :-] |
Re: Waves install
I recently installed a demo of the Ren Maxx bundle & the Transform bundle.
I noticed the ren maxx bundle installed "WaveShell-DAE 4.0_X" while the transform bundle installed "WaveShell-DAE 4.3_X" moving the previoulsy installed waveshell to the moved items folder so when running protools the transform bundle would show up while ren maxx would not. Once i moved the "WaveShell-DAE 4.0_X" back to the plug-ins folder along with the "WaveShell-DAE 4.3_X" both bundles were available in protools. |
Re: Waves install
This is slightly off topic, but after installing my Waves Platinum Bundle, I found that Final Cut Pro 4.0.2 wouldn't start. For whatever reason, the Waves installer puts an AU driver in /Library/Audio/Plug-Ins/Components folder, which FCP chokes on and causes it to quit during loading.
Per Apple's instructions, I trashed it and both FCP and PTLE now live in harmony - - which is good since I do mostly post production video sound stuff
MacPro 8X 2.26 Ghz cores, 15 GB RAM, OS 10.6.8 PT9/Waves Platinum 8/Waves Restoration Bundle 8, W43/ Cedar DNS One/iZotope Rx2/Odds and ends |
I can't install Waves 8 | jemthebullfrog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-29-2011 07:17 AM |
Waves install | DG2B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-03-2003 10:16 AM |
How I got Waves 3.5 To Install | finalcut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-03-2002 06:02 PM |
Waves NPP Install | Jimmy_Vogt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-31-2002 03:32 PM |
Where does Waves TDM install to? | SteveGarman | Pro Tools TDM Systems (Mac) | 1 | 02-02-2000 05:41 PM |
