Virtual Drummer Plug in issues
Guys,
I have the latest pro Tools first, a licensed copy of the plug in purchased through the marketplace. It’s downloaded to the correct files on the Pc as per the instructions. I've deleted the app data preferences a few times, restarted the computer. I’ve got a stereo instrument track open but it’s still not showing up, all I can access is expand2 and the normal stock plug ins. Any ideas what I’m doing wrong? |
Re: Virtual Drummer Plug in issues
Is the .aaxplugin file actually in the plugin folder, what exact full file path? .. just tell us the hard facts instead of telling us you think stuff is correct.
Do you see the plugin load at Pro Tools Startup? Does the instrument need to be inserted on a stereo instrument track? What track are you trying to work on? << pay attention to this Are you looking in the correct multichannel or multimono insert pulldown menu? << pay attention to this Have you read the documentation for the plugin? (esp. related to the two points above). |
Cheers,
VD-HEAVY.aaxplugin is sitting in this file path ( My system is 32bit Windows 7) C:\Program Files\Common Files\Avid\Audio\Plug-Ins its also sitting here: C:\Program Files (x86)\Common Files\Avid\Audio\Plug-Ins and I`ve followed this from the UJAM website. Many users asked us, how the initial set up of UJAM Instruments Plug-ins works in Pro Tools. Well, here is the answer: Please make sure, that you have installed the AAX plug-in file to this location: OSX - {SYSDRIVE}:/Library/Application Support/Avid/Audio/Plug-Ins Win 32-bit - {SYSDRIVE}:\Program Files (x86)\Common Files\Avid\Audio\Plug-Ins Win 64-bit - {SYSDRIVE}:\Program Files\Common Files\Avid\Audio\Plug-Ins Note: If you use a custom AAX folder you’ll have to move the file there manually. Additionally, you might want to know how to properly use UJAM Instruments plug-ins in Pro Tools. Of course, there's an answer to this question too. Come along: Create a new Stereo instrument track Load either Virtual Guitarist, Virtual Drummer, or Beatmaker as a Multichannel plug-in (please find it in the “UJAM” folder of that category) Please note that this workflow doesn't apply to a Mono channel or as a Multi mono plug-in. |
So are you really sure you are using a stereo instrument track? That is a really common issue and easy mistake to make. Don’t assume, actually go check.
Do you see the plugin load at startup? |
Do they have a AAX32 bit version in that download otherwise it won't work as most plugins are AAX64 bit nowadays. Check that with UJAM website. PT First os a 64 bit app and which only runs AAX64 bit plugins.
Does it state the VD is compatible with a 32 bit win system on the download site?
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
I believe that this is an on going issue and the IT team is already working on this. It would be best to open a support case through http://avid.force.com/Support/Regist...eation#s=step1 so they can monitor the issue under your account. |
Cheers for the help guys, I’ll get onto the support case in a minute.
The 32bit files are showing in the folders, on startup it says plugins are being loaded but it dosnt specifically mention the UJAM ones. I’m opening the stereo track from the Top tool bar , New Track and then selecting stereo and instrument as the types. Then adding the plug ins which only as stated above, only give me access to the standard ones and expand 2. |
Virtual Drummer on PowerBook G4 and PT 8 | captain54 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-04-2015 09:28 AM |
Help with Strike Virtual Drummer | spc1968 | Virtual Instruments | 20 | 04-28-2011 01:15 AM |
Best virtual drummer for Mac G5 | Joe Egan | Virtual Instruments | 0 | 12-17-2009 10:24 AM |
virtual drummer, horns | llamadelyo | General Discussion | 0 | 06-08-2002 12:36 AM |
virtual drummer | underscore7 | General Discussion | 3 | 02-06-2001 02:08 AM |
