Old 07-21-2010, 01:26 PM
montreal montreal is offline
Default make a bounce on half speed..
some of you know that when you push play button and shift at the same time you hear your tracks in half speed...
now can you tell me if i can record it thrue a bounce ? if not what can i do to record it ?
thx
Old 07-21-2010, 01:45 PM
daeron80 daeron80 is offline
Default Re: make a bounce on half speed..
I would use Pitch Shift (Audio Suite plugin) for that. Uncheck Time Correction, and set Coarse to -12 semitones.
Or if it's short enough to be manageable, RAM-wise, drop it in a sampler like Structure (the free version will work as well as any) and play it back an octave low. The advantage of that is you can play it back anywhere on the keyboard and get instant audible feedback as to whether it's the pitch/speed you want.
David J. Finnamore
Nyquist was right.
PT 2018.x HD | Omni | macOS Sierra
PT 2018.x | Saffire Pro 40 | Win10
Old 07-21-2010, 07:34 PM
it works perfectly
thanx a lot my friend
Old 07-22-2010, 02:06 PM
Slate416 Slate416 is offline
why not route your main output to a new track using an empty bus, and record @ 1/2 speed and export.
Old 07-22-2010, 02:09 PM
Try it and see.
David J. Finnamore
Nyquist was right.
Old 07-24-2010, 03:22 PM
kRokksOn kRokksOn is offline
Talking Re: make a bounce on half speed..
Originally Posted by daeron80 View Post
try it and see. :d
And please report back the results...
"lyrics, wasted time between solos!"
kiddipalli@simnet.is
syrland.is
myspace.com/kiddipalli
Old 07-27-2010, 04:48 AM
can you tell me guys how to do that ? recording directly 1/2 speed ? how ?
Old 07-27-2010, 05:22 AM
Ben Jenssen's Avatar
Pretty obvious.
Record a half-speed source at half speed, play it back at normal speed = normal speed.
Old 07-28-2010, 04:52 AM
can you tell me how you do that without going out of PT please ? and without using any pitchtime fx...
Old 07-28-2010, 05:02 AM
You can playback at half speed by holding down shift while pressing spacebar.
My point was: If you hold shift AND cmnd while pressing spacebar to RECORD (I haven't even checked if that's possible), sending audio from one track to another by a bus, then the recording track would record at half speed. Ergo: no change in playback at normal speed.
Can you bounce in Half speed electronicnoise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-27-2004 08:43 AM
Bounce at Half Speed torquemada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-26-2004 01:21 PM
Bounce to Disk at half speed? SteveGarman Pro Tools TDM Systems (Mac) 3 07-29-2004 07:11 PM
shortcuts for half speed +dbl speed recoring neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-09-2003 02:48 PM
Can you bounce to disk at half speed? LATablette 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-21-2002 08:34 PM
