#41
Re: iPad Non-Pro 9.7" 7th Gen
Got it. What’s next after that?
#42
Did renaming not work then ?
Also, the iPad that does show up...does it drag over to the right-hand column in EuControl ? |
#43
What’s next? Last edited by JGM; 12-11-2017 at 05:22 PM. |
#44
Were you able to drag over to the right hand column? (Sorry can't call at the moment, with my kids)
In PT make sure EUCON is checked in Peripherals |
#45
Also did set up PT correctly. Even making sure that I selected WiFi. But when I tried to select a controller from the listing, it still says none. |
#46
The good news is in EuControl the iPad App is now seen and connected correctly. |
#47
Sorry if this makes no sense. If this makes sense to you, what did I do wrong? |
#48
Don't turn on Ethernet, See attached from the guide.
If WiFI is turned on in your Mac Network Prefs but you are connected by an Ethernet cable turn it off. Make sure to reboot if you do this. |
#49
Done. Still says Not Connected.
#50
OK. Let me go back and clarify a few things then because it should be working from what you tell me.
With all this can you multi-finger swipe up on the iPad and then force quit the Control App. Then restart it and report back. If you can't do that, then hold the power key down on the iPad until it says shut down...do that and restart. Report back.... |
12.9" iPad Pro...anyone?? | topaz1s | Avid S1, S3, Dock and Control App | 0 | 02-18-2017 07:39 PM |
iPad Pro 9.7" VS. iPad Air 2 ? | reichman | Avid S1, S3, Dock and Control App | 1 | 08-07-2016 10:46 PM |
"Instrument names reappear after changing fonts on iPad Scorch" | jccmusic | Avid Scorch (iOS) Forum | 1 | 12-02-2011 02:03 AM |
Will the ipad?".......... | barters81 | General Discussion | 4 | 04-13-2010 12:06 AM |
