Old 05-25-2011, 03:34 PM
towelhead towelhead is offline
Default Multiple interfaces to PT9
I am trying to hook up multiple interfaces to PT9. I've got a FirePod daisy chained into a 003, which is subsequently daisy chained into a LaCie HDD.
Everything I've read so far says that it can't be done. I just want to verify that. Also, I'm pretty new at this, so layman's terms would be much appreciated.
Old 05-25-2011, 05:35 PM
Craig F Craig F is offline
Default Re: Multiple interfaces to PT9
for clarification:
you want to take the output of the FirePod to the input of the 003? (I don't know the FirePod but I would thin this is posable)
or
both the FirePod and the 003 connected to the computer and active at the same time? (this is not posable)
Thank you,
Craig
Old 05-25-2011, 08:32 PM
Yea, I would want to run both the FirePod and the 003 at the same time. So there is no way to do it, then. Bummer. Thanks for the info though, much appreciated.
Old 05-26-2011, 10:18 AM
appledude appledude is offline
The problem is that the Digi 003 will not do aggregate devices. So no you cannot use them together. There may be a device that will aggregate with your firepod. If you had a Digimax D8 instead of the firepod, you could have used the lightpipe into the digi 003.
Imac Pro 27" 10-core with a LG 4K for a second screen
OS 10.14.4
Pro Tools 2019.6
UAD Apollo X8P With an extra 8 channel ADAT using
a Focusrite Liquid Saffire 56
UAD Twin duo
UAD TB3 Octo Satelite
Focal Twin Be monitors
samsung T5 and Gdrive
Multiple interfaces in pt9 HD? muddboy macOS 7 05-12-2013 11:23 AM
Multiple interfaces Julia B Pro Tools M-Powered (Win) 3 06-22-2011 08:07 PM
multiple interfaces with pt9 rivetheadsound Pro Tools 9 22 04-21-2011 10:33 AM
Multiple Interfaces? grimepoch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2008 06:30 AM
AES/EBU on multiple 96 interfaces Robin Reumers Pro Tools TDM Systems (Mac) 0 10-12-2006 09:41 AM
