Old 02-14-2020, 12:15 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: Record an orchestra
Originally Posted by JFreak View Post
Orchestral music is rarely performed against constant tempo. It fluctuates, which means using seconds in main meter. I believe seconds are same length for each song, aren't they
That depends on how fast you're traveling while recording!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 02-17-2020, 09:20 AM
DetroitT's Avatar
DetroitT DetroitT is offline
1 large session for tracking (keep all at sample base)
Most composers have feel tempos plus engineering needs to keep consistent take and pickup tempo/ meters. (Make detail accuracies in post)
Have a click (no accent) tap during rundown record then off as a pre count reference.
Or score markings (allegro=132 bpm) Leave space between sections.
Adding meter ID+ Can bring start for pre-count measure to 1
Could go on...
For me I stay linear and use playlist duplicate for every part (group all)
Clean up later.
Old 02-26-2020, 02:27 PM
chris.d chris.d is offline
as soon as overdubs are an option i try to have 1 session per song.
overdubs call for playlists pretty fast. (can we just quickly redo section C with the 1st violins only? o wait, let's use it as a double) an there goes your template...
add playlists and groups, occasionally add a few tracks and do that on a all-songs-in-one-session and desaster is near. if you add a track to a group that already had playlists, funky things can happen when changing playlist...
i recently got a session of a piano trio to mix that was build in this manner. 340 ***ing tracks, for a jazz TRIO!!!
with mutes, deactivated, cryptic tracks, takes, playlists allover the ***ing place. it took me 1 day and a few phone-calls and session-pics mailed accros the globe to get this sorted so that i eventually could START mixing.
It takes less than 1 minute or the time to properly tune a violin to do a SAVE AS, hit CMD SHIFT A, CMD SHIFT B and remove all markers and you are ready to go.
Old 03-25-2020, 11:31 AM
I have definitely used the Bar 1 then Bar 101 (or 1001) then Bar 201 (or 2001), etc. for each cue. This requires the session to be setup that way in the first place, but can work quite well.
Another option would be to "Renumber Bars" each time you jump to another cue/song.
Scott Gatteño
What's the best way to get an orchestra in the mix? SWBoatman25 Tips & Tricks 2 01-12-2016 01:08 AM
HD for orchestra library? villagesound Pro Tools TDM Systems (Mac) 5 03-30-2009 10:29 PM
Garritan Personal Orchestra Vs Symphonic Orchestra Re_Org General Discussion 0 08-02-2004 06:57 AM
Mixing with Orchestra vogue Tips & Tricks 1 06-09-2004 05:13 PM
orchestra goeperd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-08-2000 03:28 PM
