Old 10-04-2005, 09:16 AM
028 028 is offline
Default Play and hear instruments in record enable
Hey Guys,
I'm not that proficient in Pro-Tools (LE 6.9 BTW), so I would appreciate your assistance with a lil' something I'm sure is quite simple:
I want to be able to play along previously recorded tracks without necessarily recording. Right now if I hit play while some tracks are record enabled, the previously recorded tracks (not enabled) play, but no sound comes out of the enabled ones. Basically this would be for rehearsing purposes.
THX
028
Old 10-04-2005, 09:26 AM
spkguitar's Avatar
Default Re: Play and hear instruments in record enable
Check/change your record monitoring mode. (alt+k)
From Chapter 11 of the reference guide:
Auto Input Monitoring
In Auto Input mode, when session playback is
stopped, Pro Tools monitors audio input. When
playback is started for a punch-in, Pro Tools
monitors existing track material up until the
punch point. While punched in, the input signal
is monitored. On punch-out, monitoring
switches back to the existing track material. This
is similar to the auto-switching logic found on
digital and analog multitrack tape machines.
Pro Tools TDM systems include TrackInput
controls for setting the monitoring mode of
individual tracks. See “Selecting Record
Monitor Modes with TrackInput” on
page 149.
When using Auto Input, the switch back to
monitoring track material on punch-out is
not instantaneous.
Input Only Monitoring
In Input Only mode, when a track is record enabled,
Pro Tools monitors audio input only, regardless
of any punch-in/out selection.
When Input Only monitoring is enabled, the
Green LED next to the Transport window appear
green.
To select a record monitoring mode in Pro Tools
LE, do one of the following:
  • To use Auto Input monitoring, select Operations-> Auto Input Monitor.
– or –
  • To use Input Only monitoring, select Operations-> Input Only Monitor.
To toggle between Auto Input and Input
Only monitoring, press Alt+K (Windows)
or Option+K (Macintosh).
Old 10-04-2005, 09:28 AM
yavuzj yavuzj is offline
OK. I may be mistaken since I have not tested this.
Try adding an Aux Track.
Choose the input as the physical input of the instrument that you want to hear.
Send the out put to a bus. then create an audio track and choose the input of the same bus.
Then you should be able to hear w/o record enabling.
If this gives you problems,
then you can create an aux track and choose the input as the input of your instrument.
THen create and audio track and choose the same instrument input.
Play along thru the Aux track and
when you want to reacord, record enabl the audio track but remember to mute the aux track.
I hope this was not so confusing.
Yavuz AKYAZICI
Guitar Player, Composer
http://cdbaby.com/cd/volcano
http://volcanojazz.com
http://myspace.com/volcanojazz
Old 10-04-2005, 09:35 AM
028 028 is offline
Wow, that was fast.
Thanks a bunch guys. SPKGuitar you shure know your manual dude! Honestly I didn't even checked the manual as I didn't know what to look for.
Again thanks a lot,
028
Old 03-16-2018, 11:17 AM
Bedrocks Bedrocks is offline
I'm trying to record a drum track using Boom insert - Pro Tools 12.8.3. When I record enable the track, I can't hear it. If I go to the track to switch to Input-only monitoring, that option is grayed out!
Mac Pro HD with a 2.8 GHz Quad-Core Intel Xeon processor, OS X version 10.10.5, ProTools 12 version 12.8.3
Old 03-16-2018, 11:25 AM
PS, I already turned off low-latency monitoring
When I enable a track to record and then hit 'play' the track will remain silent Rainerbird Pro Tools M-Powered (Win) 2 08-07-2009 09:41 PM
Why can I only record enable/play one midi track at a time? Martin Dubka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2008 01:24 PM
PT 7.3 Can't hear signal after record enable Celestial 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-05-2007 02:25 AM
PT 7.3 Can't hear signal after record enable Celestial 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-05-2007 12:51 AM
Let me hear your digi 001,Post your music that you record hear optymusblu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-05-2003 12:52 AM
