Old 09-26-2005, 04:16 PM
wakebrder03 wakebrder03 is offline
Default Creating Midi Track Crashes Pro Tools 6.9.2
I am running Tiger on a powerbook 1.67. Whenever I try to create a new midi track Pro Tools crashes to the desktop. I tryed removing it and reinstalling protools and the same thing occured, any ideas.
Protools 6.9.2
Powerbook g4 1.67
Digi 002 Rack
Keystation 49keyboard
Old 09-26-2005, 08:27 PM
Default Re: Creating Midi Track Crashes Pro Tools 6.9.2
so i have been running some tests to try to trace down the problem. It seems it only crashes when the m-audio keystation 49e is connected via usb. When I disconect it, create tracks, then reconnect it everything is fine. I checked the m-audio website for drivers, but it says the keyboard dosen't require any. Is this just a feature of buying a cheap Midi Controller? Or is there something else i can do to solve this?
Chris
Old 09-27-2005, 10:58 AM
DigiTechSupt's Avatar
Go to MacHD>Users>your account>Library>Preferences>By Host and trash 'com.apple.midi.a bunch of numbers and letters.plist'.
Go to MacHD>Users>your account>Library>Preferences and trash 'com.apple.audio.audiomidisetup.plist'.
Empty the trash and restart, then see if everything is working.
Avid Audio Tech Support
Support FAQ
Old 10-01-2005, 12:45 PM
Acky Acky is offline
Hi, I think I had the same problem - MIDI tracks in Pro Tools prevented the file from playing. When I pressed play on the transport bar, stop would press itself immediately.
I deleted the files that you mentioned, BUT I still can't get my MIDI devices to play through Pro Tools (nor through Noteability Pro). Both of my MIDIsport devices seem to be getting no input from the computer: the new 2X2 that I am trying to test, and the 1X1 that has worked for a couple of years on another (PC) system.
I am wondering if there is a conflict with the MBox that will not allow me to use these devices on the same system. Do I need to get one of the MIDI interfaces approved for use with MBox?
I am running Tiger on an iMac G5 (brand new)
Thanks!
Which version to run? Pro Tools quits when creating MIDI track - or Yellow interfaces Belegur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-06-2010 05:56 AM
MIDI Track creation crashes Pro Tools dlcatftwin Pro Tools TDM Systems (Mac) 0 11-12-2007 06:36 PM
Creating MIDI track crashes PT nanners MIDI 2 06-06-2007 03:50 PM
Creating a Midi track crashes PT! wehavethefacts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-24-2005 06:20 AM
LE Crashes When Creating MIDI Track mmunson MIDI 1 11-07-2003 06:31 AM
