Old 08-04-2002, 11:44 AM
VILLADON VILLADON is offline
Default velocity
I have an MPC-3000 and a Midi keyboard, I would like to know how you can set up SSC to respond to velocity sensitive pads from the MPC, I have a multi sample instrument loaded with drum sounds, when i hit a pad on the MPC it plays at the full volume level, even when i hit it very light. In other words SSC doesnt respond to velocity. I tried the same thing with the midi keyboard. Is there a setting i am missing here?
Thanks.
Old 08-06-2002, 08:02 AM
DigiTechSupt's Avatar
Default Re: velocity
I use a Roland PC200MKII keyboard controller and have no problems with SSC tracking the strength at which I trigger the keys.
Are you sure that both your MPC and Keyboard transmit velocity data at their MIDI Outputs?
Brent
Avid Audio Tech Support
Support FAQ
Old 08-06-2002, 01:07 PM
Still No SSL Yet Still No SSL Yet is offline
Villadon I too am a bonafied MPC user. I see you've chosen ssc over the expense of a MPC4000. Tell me what's the maximum amt of sampling I can expect on a G4 466 with 1.5Gig of ram??? And has latency been a problem for you?? Man I love sampling at 24 bit but how do u split outputs? Do I have to make an instrument for each sound????
Old 08-06-2002, 01:09 PM
HTML code is On
Can't edit velocity only anymore? Notes copying with velocity data... kingtinker Pro Tools 10 5 11-12-2011 10:53 AM
Any way to set the default velocity? Mike1983 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-14-2009 06:25 PM
Zero velocity? JohnnyMarks MIDI 4 03-29-2007 09:50 AM
Any one else with velocity bug 7.2 KimSira Pro Tools TDM Systems (Mac) 1 10-11-2006 07:07 AM
velocity controls ___? Equality 7-2521 Tips & Tricks 1 07-17-2005 07:51 PM
