-6031 errors, clicks and pops
Issue 1. The Command 8, I installed the drivers for the command 8 when Pro Tools was originally installed. When I check peripherals in Pro Tools it shows, Type Command 8, but the receive from and the send to show USB audio device. I looked at the drop down to see if the command 8 was listed and it was not. The Command 8 appears to be working but I'm concerned it's not right. When I check Device Manager it's shows as a USB Audio Device and has the Micrisoft drivers version 5.1.2535.0.
Issue 2. System Error (-6031). The system shuts down occasional and has this error message. “ Overload CPU, Check for compatible disk drivers and try the following remove RTAS plug-ins increase “HW” buffer size in the playback engine dialog, or thin automation (-6031). I increase the “HW” buffer to 512 and the DAE playback buffer is set to Level 2. Issue 3. I'm getting some clicks, tics and pops, This only appears to happen occasionally. I believe it may have something to do with 1 and 2 above. Any help or direction you could provide would be greatly appreciated. Thank You Arnie Larsen. System Summary Manufacturer : PCAudioLabs Mainboard : Gigabyte EX58-UD5 Chipset : Intel X58 Processor : Intel Core i7 960 @ 3200 MHz Physical Memory : 8192 MB (4 x 2048 DDR3-SDRAM ) Video Card : ATI Radeon HD 4300/4500 Series Hard Disk : ST31000528AS (1000 GB) Hard Disk : ST31000528AS (1000 GB) Hard Disk : ST3250318AS (250 GB) DVD-Rom Drive : PIONEER DVD-RW DVR-218L Monitor Type : Samsung SyncMaster - 23 inches Network Card : RTL8168/8111 PCIe Gigabit Ethernet Adapter Network Card : RTL8168/8111 PCIe Gigabit Ethernet Adapter Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 3 DirectX : Version 9.0c (March 2006) Mainboard Manufacturer : Gigabyte Technology Co., Ltd. Mainboard : Gigabyte EX58-UD5 Bios : Award Software International, Inc. Chipset : Intel X58 Physical Memory : 8192 MB DDR3-SDRAM LPC bus : Yes PCI Bus : Yes Bus PCI-Express : Yes USB Bus : Yes SMBus/i2c Bus : Yes Bus HyperTransport : No Bus QPI : Yes Bus CardBus : No Bus FireWire : Yes Processor Processor : Intel Core i7 960 Frequency : 3200 MHz - (current : 3238.49 MHz) Number of Core : 4 Support : Socket 1366 LGA Cache L1 : 4 x 64 KB Cache L2 : 2 x 256 KB Cache L3 : 4 x 8192 KB FPU Coprocessor : Present Core 1 Activity : 0% Core 2 Activity : 0% Core 3 Activity : 0% Core 4 Activity : 0% Video Number of monitor : 1 Monitor Type : Samsung SyncMaster Video Card : ATI Radeon HD 4300/4500 Series Current Display : 1440x900 pixels at 60 Hz in True Colors (32-bit) OpenGL : Yes GDI Plus : Yes I\O Ports Port installed : Intel(R) ICH10 Family USB Universal Host Controller - 3A37 Port installed : Intel(R) ICH10 Family USB Universal Host Controller - 3A38 Port installed : Intel(R) ICH10 Family USB Universal Host Controller - 3A39 Port installed : Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C Port installed : Intel(R) ICH10 Family USB Universal Host Controller - 3A34 Port installed : Intel(R) ICH10 Family USB Universal Host Controller - 3A35 Port installed : Intel(R) ICH10 Family USB Universal Host Controller - 3A36 Port installed : Intel(R) ICH10 Family USB Enhanced Host Controller – 3A3A Drives Number of Disk Controller : 2 Number of Hard Disk : 3 Number of CD-ROM Drive : 1 Drives Letters : C:\ D:\ E:\ F:\ Drive C: (Hard Disk) : 231 GB available on 250 GB Drive D: (DVD-Rom) : 0 KB available on 0 KB Drive E: (Hard Disk) : 956 GB available on 1000 GB Drive F: (Hard Disk) : 992 GB available on 1000 GB Devices Type of mouse : PS/2 Compatible Mouse Type of keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Joystick : None HID Devices : No SCSI Host #0 : 4 Device(s) SCSI Controller : GIGABYTE GBB36X Controller Device : Motorola 56361 Audio I/O Controller (MIDI) Device : Motorola 56361 Audio I/O Controller (MIDI) Device : Motorola 56361 Audio I/O Controller (MIDI) Device : Motorola 56361 Audio I/O Controller (MIDI) Device : Motorola 56361 Audio I/O Controller (MIDI) Device : Motorola 56361 Audio I/O Controller (MIDI) Trusted Platform Module : No Multimedia Device Audio : 82801J (ICH10) HD Audio Controller Device Audio : 82801J (ICH10) HD Audio Controller Device Audio : 82801J (ICH10) HD Audio Controller Audio Playback : Realtek HD Audio output Audio Playback : ATI HD Audio rear output Audio Playback : Microsoft Sound Mapper Audio Recording : Realtek HD Audio Input Audio Recording : Realtek HD Digital input MIDI Output : USB Audio Device MIDI Output : USB Audio Device [2] MIDI Output : USB Audio Device [3] MIDI Output : Microsoft GS Wavetable SW Synth MIDI Output : Microsoft MIDI Mapper MIDI Input : USB Audio Device MIDI Input : USB Audio Device [2] Mixer Device : Realtek HD Audio output Mixer Device : ATI HD Audio rear output Mixer Device : Realtek HD Digital input Mixer Device : Realtek HD Audio Input Device multimedia : AVIVideo Device multimedia : CDAudio Device multimedia : Sequencer Device multimedia : WaveAudio Device multimedia : MPEGVideo Audio Compression : Microsoft IMA ADPCM CODEC Audio Compression : Microsoft ADPCM CODEC Audio Compression : Microsoft CCITT G.711 A-Law and u-Law CODEC Audio Compression : Microsoft GSM 6.10 Audio CODEC Audio Compression : DSP Group TrueSpeech(TM) Software CODEC Audio Compression : Microsoft G.723.1 CODEC Audio Compression : Windows Media Audio Audio Compression : Sipro Lab Telecom ACELP.net audio codec Audio Compression : Indeo® audio software Audio Compression : Fraunhofer IIS MPEG Layer-3 Codec (advanced) Audio Compression : Microsoft PCM Converter Video Compression : Cinepak Codec by Radius Video Compression : Intel 4:2:0 Video V2.50 Video Compression : Intel Indeo(R) Video R3.2 Video Compression : Intel Indeo(R) Video R3.2 Video Compression : Intel Indeo® Video 4.5 Video Compression : Intel IYUV codec Video Compression : Microsoft RLE Video Compression : Microsoft Video 1 Video Compression : Microsoft YUV Video Compression : Microsoft YUV Video Compression : Toshiba YUV Codec Video Compression : Microsoft YUV Video Compression : Microsoft H.263 Video Codec Video Compression : Microsoft H.261 Video Codec Video Compression : Indeo® video 5.10 Network Network : Yes RAS Connection : No Passport.Net : No Winsock32 : v2.02 Network Connection : Local Area Connection Network Connection : Local Area Connection 2 Network Connection : 1394 Connection 4 Network Card : Realtek RTL8168D(P)/8111D(P) PCI-E Gigabit Ethernet NIC Network Card : Realtek RTL8168D(P)/8111D(P) PCI-E Gigabit Ethernet NIC Network Card : 1394 Net Adapter Local Group : Administrators Local Group : Backup Operators Local Group : Guests Local Group : Network Configuration Operators Local Group : Power Users Local Group : Remote Desktop Users Local Group : Replicator Local Group : Users Local Group : HelpServicesGroup Local Group : Pro Tools Users |
Re: -6031 errors, clicks and pops
I'd love to get this solved too. I have the same mobo but with the i7 940 cpu. I have followed all the suggested tweaks. I have changed card slots. I have disabled all C states in Bios etc.
I still get 6031 errors. I have come to the assumption that PTHD 8.03 cs2 hates our setup. I have been using Nuendo4 in the interim whilst waiting for a major PT update. I'm hoping they get this sorted. Oh and this occurs with XP 32 bit as well as Win7 64 bit. Cheers
i7 940 / EX-58 / 6 gig corsair / ATI 4670 / PT9 / UAD2 Quad / Apogee ad/da 16x's / 2 x RME HDSP9652 |
Thanks
If you have not already figured out the random clicks and pops...try increasing the H/W buffer size. I had a similar issue on a CD I was mastering for a national release...drove me nuts and I originally thought there was a dithering issue combined with a clock issue.
Turns out that PT8.0.3 does NOT like anything less than 1024 samples on the buffer size. The random clicks and pops disappeared once I set to 1024. |
There are several possible solutions for this, among them are:
1. Reverse the card order in the computer. 2. If you have multiple HD cards, reduce it to 1 card and see if the symptoms continue. If they do, try another slot. If they don't, add another card until the system is back together. 3. Update ALL drivers - and make sure they're updated. One customer had a network driver that he installed an update for, only to find out the update didn't 'take' until he manually chose the right driver. 4. If you have an NVidia card, make sure it's running a driver version higher than 1.81. You may have to try a couple different driver versions to find the one that workd properly on your system. 5. Disable your network card, wi-fi, bluetooth any other hardware that's not absolutely necessary to work in Pro Tools. All of those can cause interrupts that cause this error. 6. Follow the rest of the configuration and optimizations in the General Troubleshooting thread. If, after you've tried all that, you're still having problems - please provide a Sandra report and a DPC latency report (make sure you have Pro Tools running when you do the DPC test) and a complete, detailed report about what you have or have not done. |
Thank you I increased the H/W buffer size a couple days ago I'm keeping my fingers crossed but no pops or clicks, I'm now working on the 6031 thing. I'm going to work on tech solutions for this over the weekend, wish me luck
Hope that helps. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Shane
Finally had a chance to get back to this.
I swapped the ATI4670 video card from slot 1 of the Mobo to slot 2 and placed the magma PCIe card into slot 1. I was previously running the magma into the 8x slot because it's an 8 times card. It's now in the 16x slot 1 usually reserved for video. I've now run PT8.04 on Win7 64 bit all morning in 96k and haven't got any 6031 errors. I'm calling this sorted. Thanks for your help. Cheers
Shane
Continue 6031 errors | Parisstudio | Pro Tools TDM Systems (Win) | 3 | 11-26-2012 03:02 PM |
random 6031 error and clicks- protools HD | Oaudio | Pro Tools TDM Systems (Win) | 3 | 10-18-2011 01:51 AM |
constant -6031 errors on PT 9 | jonathan jetter | Pro Tools TDM Systems (Win) | 22 | 12-20-2010 06:59 AM |
8.0.1 cs1 still 6031 errors | kinghand | Pro Tools TDM Systems (Win) | 30 | 11-18-2009 11:29 AM |
-6031 errors | Mark Wheaton | Pro Tools TDM Systems (Mac) | 13 | 12-20-2003 05:08 PM |
