Sustain pedal choppy during Record only
When I play VI's like Velvet, EW Pianos, Kontakt etc during record mode the sustain, when I press the sustain pedal on the keyboard, is choppy. The sustain notes do not consistently hold throughout the performance - they prematurely cut off.
This only happens during Record mode. The sustain is fine during record mode in Cubase 5 so it has to be something with Pro Tools. Completely clueless to why this is happening. SiSoftware Sandra Computer Model : Gigabyte X58A-UD3R Workgroup : WORKGROUP Host Name : UMP-PC User : UMP Processor Model : Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte X58A-UD3R BIOS : Award (Phoenix) Fb16 08/02/2010 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 6GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 798MHz (1.6GHz) Memory Module(s) Memory Module : Corsair CMX6GX3M3C1600C7 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMX6GX3M3C1600C7 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMX6GX3M3C1600C7 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : ATI Radeon HD 5400 Series (80 SM5.0 650MHz, 512MB DDR3 2x400MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 5400 Series (80 SM5.0 650MHz, 512MB DDR3 2x400MHz, PCIe 2.00 x16) Graphics Processor STREAM Processor : ATI Radeon HD 5400 Series (160SP 2C 650MHz, 512MB 2x400MHz) Compute Shader Processor : ATI Radeon HD 5400 Series (80SP 650MHz, 501.4MB 2x400MHz) Storage Devices WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (D:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (E:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) : 932GB (C:) TSSTcorp CDDVDW SH-S223L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices Audio (D:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) Library (E:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) System Reserved : 100MB (NTFS) Hard Disk (C:) : 931GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm, NCQ) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223L (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Audio Device : PC Partner Manhattan HDMI Audio [Mobility Radeon HD 5000 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : Giga-Byte 6 port SATA AHCI Controller Disk Controller : Giga-Byte 88SE9128 SATA-600 Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 3.9 EDIT: *First I noticed that my RAM timings were at 9-9-9-24 and should have been at 7-8-7-20. Changed that then switched the S90XS to MULTI/SEQ PLAY mode. All is well again... :)
MIDI Sustain Pedal Drop Out During Record | yanndublin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 44 | 07-06-2015 02:12 PM |
MIDI Record Piano no sustain pedal | MarkWorsnop | Pro Tools 10 | 1 | 06-17-2013 08:58 AM |
Sustain pedal drops out on record | audiopostpicture | MIDI | 4 | 06-21-2010 03:37 PM |
Make my sustain pedal a kick pedal | dr beef | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-11-2005 12:20 AM |
Make my sustain pedal a kick pedal | dr beef | MIDI | 0 | 05-08-2005 10:14 PM |
