Old 10-10-2011, 09:39 PM
wesplaysguitargood wesplaysguitargood is offline
Default Playback silence for first 1/2second. & Cant Import mp3's?
Simple issue. Whenever I Import Audio <shift+command+I> I can't convert or import any MP3's through itunes, I can go around and search for the actual mp3 in my computers itunes folder, but used to be able to import that way through PT8. Quick Fix??
BIGGER ISSUE
(in playback) there's a split second of silence before ANY audio playback, as if there is a quick fade before the very first audio waveform. (Or bad compression settings) It also happens if there is more than half-one second of silence in my session. When I try to IMPORT samples of Kicks or Snares (and am simply previewing them in playback) its like they all have fades on the front of them. Its NOT my samples because its doing this to every waveform through into protools, even midi, even the first 'Click' on my click track.
Say I import 4 kicks into PT.. 1st kick (sounds like a fade "woommff" next 3 kicks "punch punch punch")
Please help!!!
Old 10-11-2011, 03:01 PM
remusjacobs remusjacobs is offline
Default Re: Playback silence for first 1/2second. & Cant Import mp3's?
For importing any audio file use the workspace tool.
Issue trying to load/import mp3's.2nd time Ive post. Can U help??? eddiebrumley Pro Tools M-Powered (Win) 1 09-26-2011 08:50 AM
Cannot Import MP3's ampeck2 Pro Tools 9 2 11-30-2010 07:15 AM
PTLE 8.0.4 recording/metering problem (input mon. playback fine, but records silence) blast9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-17-2010 08:45 AM
AIII playback is destorted even in silence Tech Budha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-17-2002 02:55 PM
Import MP3's? jasbart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-12-2000 10:07 AM
