Old 03-23-2003, 09:06 PM
MrMike MrMike is offline
Default how to reduce the length of a song!
I hope I explain this clearly....
I use a drum machine to lay down a MIDI click track and ascratch drum track. Once I get a couple measures of click and drums recorded I use the repeat command to add more measures (saves time). Since I generally don't know how long the tune is going to be when completed I tend to add maaannnny more measures than I would need. I then record the click and scratch drums to audio. I am then ready to do the basic tracks for the rest of the instruments.
Once I get the format of the tune down and some basic tracks recorded I know how many measures I actually need. I then highlight the unneeded measures of click and drums and delete.
I then bounce to disk. While the tune itself is about 4 minutes the length of the tune being bounced is 16 minutes. It must have something to do with the extra measures I added and then deleted. It is like PT still sees the deleted measures. Any tips on how to fix this?
Mr. Mike
we all must answer to the invisible whip - Rasaan Roland Kirk
Old 03-23-2003, 09:54 PM
Mr_Seven Mr_Seven is offline
Default Re: how to reduce the length of a song!
When you delete the midi from the edit window, it's still in the midi regions. Delete it and any other region that goes over the end of song from the regions list and you should be fine.
You can always indicate the song length for a bounce by selecting it in the time line.
But you might consider just connecting and using the drum machine realtime via midi.
Darren Valen
Cyberdream Studios
Old 03-23-2003, 10:00 PM
JFogarty JFogarty is offline
I usually just highlight on the edit window how much of the song I want. Its nice if you bounce different versions of the song often...
Reduce song file size... WRETAUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-01-2007 10:56 AM
song length loserfriendly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-12-2001 08:27 PM
Change the length of a song. davedog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2000 01:19 AM
Shortening the length of a song Somebody Pro Tools TDM Systems (Mac) 2 01-12-2000 05:54 PM
Song Length? doc22 Tips & Tricks 2 12-03-1999 08:02 AM
