Old 11-04-2008, 04:46 AM
dendee dendee is offline
Default increase number of plugs
my sessions only allow 5 plugs ins. is there a way to increase the number of plugs available per track?
many thanks!
mac pro 2.8 10.5.4
HD3 7.4.2
Old 11-04-2008, 04:56 AM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Default Re: increase number of plugs
No, 5 inserts ter track is the limit, but you could route the output of a track to a bus on an Aux track and you will have 5 inserts more...
Or you can wait for Pro Tools 8, with 10 inserts per track
Marc Schellekens
Delta Music Belgium - Pro Tools | HDX Studio
http://www.deltamusic.be
Pro Tools | HDX system:
Mac Pro (Mid 2012) 3.33 GHz 6-core - 32 GB RAM - OS X 10.14.6 - Magma EB7 - PT HDX3 - PT Ultimate 2019.10 - HD I/O 16x16 - HD I/O 16x16 Digital - 192 I/O - 192D I/O (x3) - SYNC HD I/O - Apogee Big Ben - Rosetta 200 - Slate RAVEN MTi2 (x2) in a RAVEN CORE Station + 2 RAVEN CORE Station Sidecars - Almost all available AAX-DSP plug-ins
Old 11-04-2008, 07:13 AM
BaileyBass BaileyBass is offline
many thanks!
mac pro 2.8 10.5.4
HD3 7.4.2
Or, you can bus the output of that track to an Aux and add 5 more, setting the output of that aux to whatever your original aux track was. Or it may suit you to do it via a send, giving you some flexibility with levels sent to the "aux" set of plugs. SB
Old 11-04-2008, 08:05 AM
JFreak's Avatar
JFreak JFreak is online now
Or, one can always learn to mix more efficiently
Janne
Old 11-04-2008, 10:44 AM
elicious elicious is offline
or, audio suite certain plugs to free up some space.
e
ihatetyping
Old 11-04-2008, 10:26 PM
roberts roberts is offline
Protools 8 has 10 inserts
Old 11-05-2008, 12:56 AM
Scott Goldberg Scott Goldberg is offline
Let's not forget turning some TDM plugs to RTAS.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 11-05-2008, 01:18 AM
'cept rtas still takes up a slot... but you knew that!
change has come
e
ihatetyping
Old 11-05-2008, 09:08 AM
FajitaTone FajitaTone is offline
what are your 5 plugs per track?
Ray Trujillo
Freelance Audio Engineer
Old 11-05-2008, 10:19 AM
colinmiller colinmiller is offline
That's great that they increased it to 10. I don't think I have ever had a problem with 5, but I have used 5 before. Nice to know there is some more headroom in case something weird needs to be done and doesn't require the whole bussing to an aux trick.
Colin Miller
Teaboy Audio
Recall Sheet Software
http://teaboyaudio.com
Native Instrument Plugs vs Stock PT-10 Plugs PatriotsBiker AAX Plug-ins 8 02-04-2013 12:19 PM
Increase - Decrease Increase H/W Buffers 6string 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-22-2008 06:37 PM
increase number of of inputs cheaply.. Scottyjoe Tips & Tricks 2 11-08-2006 06:54 PM
Buffer problems - Increase-Decrease-Increase 6string 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-17-2005 11:01 AM
iTune blues: Number nine. Number nine. Number nine. shaggy Pro Tools TDM Systems (Mac) 0 01-31-2001 09:12 PM
