Old 04-28-2008, 12:04 PM
epm epm is offline
Default keyboard shortcuts for audiosuite plug-ins
Hey all...
i've made a few keyboard shortcuts for some menu items i use often (show/hide region name) and external time code offset using system preferences in the usual way.
i tried making some more keyboard shortcuts for some audiosuite plug-ins (gain/7-band eq/signal generator) and something funny happens. they appear in the menu as if they work (the key command appears next to the name) and when i press the key command it flashes the menu... but it doesn't open the plug-in. it does...however put the plug-in outside of the folders in the audiosuite menu... which i guess makes it a little more convenient...but not quite what i was looking for. anyone seen this problem or have a thought of a workaround?
Running PT 7.2 tdm on os x.
thanks!
-Evan
Old 04-28-2008, 01:03 PM
bad jitter bad jitter is offline
Default Re: keyboard shortcuts for audiosuite plug-ins
I have the same experience. MInus that plug-in outside of the folders" -effect. 7.3.1 here.
Old 04-28-2008, 10:16 PM
guitarmongoose guitarmongoose is offline
Don't use the Command key in the Hot Key you create. The command key simulates clicking on the Audiosuite plug-in with the command key, which is why it's showing up as a favorite. At least I'm pretty sure that was the problem when I was trying it out.
-Brad Semenoff
Brad Semenoff
Sound Editor
Old 05-06-2008, 08:45 AM
epm epm is offline
thanks! that was it. used a shortcut without command instead and works great, also having those audiosuite 'favorites' is pretty handy too.
-Evan
HTML code is On
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. jessedtf Pro Tools 10 6 10-24-2012 10:42 AM
Can we get a keyboard shortcut for "PROCESS" in an audiosuite plug-in??? pshammond Tips & Tricks 0 09-25-2010 12:57 AM
Keyboard Shortcuts-Apple Thin Keyboard Brian in Charlotte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-15-2008 04:17 PM
An idea: Audiosuite shortcuts bad jitter Pro Tools TDM Systems (Mac) 22 05-17-2007 11:01 AM
Keyboard Shortcuts in Dynamics III plug-ins RobbaDobba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-17-2006 01:21 PM
