Old 04-17-2002, 12:03 AM
zenbarai zenbarai is offline
Default MIDI Machine Control out of control
Anybody got suggestions on MMC? I'm using two MIXPlus systems to mix feature films. On system #1 I have digitized video. System #2 accesses that video via MMC. System #1 generates time code for system #2 via USD.
I press play on system #2. System #1 starts playing, and system #2 joins in once it receives LTC. Or if I like, I can just press play on system #1, and system #2 will lock up to it.
It all works fine for about 15 minutes, after which it starts acting crazy, to the point where I have to disable MMC in order to continue my mix. The video will start skipping around all over the place, or sound will stop playing on system #2. Any advice, anyone?
Thanks,
Ben
Old 04-17-2002, 07:40 AM
CLee CLee is offline
Default Re: MIDI Machine Control out of control
I may be misunderstanding what you are doing but...
you don't need MMC. Turn on "generate time code via USD" on system 2 (the one with audio). Put system 1 & 2 "online", plug TC out from system 2 to TC in on system 1. hit play and vidio should chase system 2.
Is that what you are doing?
also check for a bad connection that is causing TC dropouts. When system 1 jumps around what kind of TC is showing up on the USD???
good luck
Craig Lee@Cerny American
Old 04-17-2002, 11:32 PM
I'm using LTC to lock system #2 to system #1. That's working fine. What I'm using MMC for is to be able to click somewhere on system #2's edit window and have the picture from system #1 jump to that location (and then play if I press play). That would allow me to quickly mix perspective changes, check sync on certain sound elements, etc.
Any suggestions on how to get MMC to stop acting crazy? [img]images/icons/confused.gif[/img]
Old 04-19-2002, 07:08 AM
oops,
sorry, your problem did sound a little to easy to fix.
I've never used MMC just regular machine control, so I got no idea. maybe someone else. good luck
HTML code is On
mtc and midi machine control ericlees Tips & Tricks 5 04-30-2010 12:16 PM
MIDI MACHINE CONTROL HELP!!! ez dollaz Pro Tools M-Powered (Mac) 0 08-31-2007 01:37 PM
MIDI MACHINE CONTROL - MMC Keeron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-18-2007 07:28 PM
Midi Machine Control taylor_s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-29-2005 12:48 PM
Midi Machine Control ... carlone Pro Tools TDM Systems (Mac) 0 01-03-2005 09:05 PM
