Old 08-18-2004, 01:09 PM
timmy4402 timmy4402 is offline
Default CPU Usage keeps resetting
So, I'm chronically running out of CPU power when editing my mixes. Yes, I have 12 or so tracks and several plug-ins, but the frustrating part is that I can usually play the mix once and it seems to break down the third or fourth time. If it played it the first time, why does it seem to break down?
So, I increase the CPU usage to 85%. Then it breaks down again. So, i go into to check it and it is back at 65%. Makes me wonder if part of my problem is that the CPU setting is not actually working?
I've got a Pentium, 2.4 ghz, 768 RAM, with a Firewire 7200 hard drive for the audio. It seems like a lot of computing power to break down so much.
I've followed most of the tweaks recommended on this site, so I'm wondering if it has something to do with my CPU, DAE buffer settings. (Although I feel like I've tried them all!!!)
Tim.
Old 08-18-2004, 01:27 PM
crs117 crs117 is offline
Default Re: CPU Usage keeps resetting
It sounds like you are running reason or some other rewire app. When running a rewire app your cpu usage is automatically dropped to 65% in pt so that your other app can share some computing time.
I cannot answer the rest of your question, but if you are running rewire you are probly using a lot of system resources with that app, and that may be killing you.
Christian
Old 08-18-2004, 04:32 PM
Fran d'Valle Fran d'Valle is offline
hello, Are you using any D-Verb on your session?¿?¿
the d-verb has a little big problems in PC with some intel chipsets...
regards.
www.digitalsoundstudios.com
Old 08-20-2004, 06:53 AM
x9blade x9blade is offline
i use reason rewired intoPT's and i'm able to have 85% on my cpu in PT's.When i use a malmstrom in reason cpu defaults back to 65%
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
Why does my digi 002 keep resetting?? jois 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-23-2005 10:44 PM
HTDM not showing CPU usage in the system usage Brandonx1 Pro Tools TDM Systems (Win) 3 12-19-2004 09:45 AM
Resetting a HUI? studiomusic Digidesign Hardware & Software 0 06-26-2003 01:14 PM
Fader not resetting ernstg ICON & C|24 4 07-15-2001 12:18 AM
