Mtc video slave setup
Hello, can someone help me with the setup of pro tools and mtc video slave? As I can understand pro tools needs to output midi timecode to mtc video slave. I have tried some options but it does not work. Thanks in advance
Sent from my Redmi Note 4X using Tapatalk |
Re: Mtc video slave setup
All you need to do is to send out MMC and MTC to the same MIDI output which should then be wired to the MIDI input of your slave machine. Turn on MTC in the transport window and it should work.
The settings of where you're sending MTC are in Setup/Peripherals under the MTC Generator tab.
sent from a stupid phone using Tapatalk |
And MMC is on the Machine Control tab.
Thank you all for your answers. I have done that. At least I think so :). And it does not work. Here are the pics
I must be doing something wrong. These are the midi devices that are available from the drop down menu
It looks right to me. I think at this point I'd look to the slave application....?
I don't use MMC and only use MTC between two devices via a MIDI cable, so you're beyond my first-hand knowledge. sent from a stupid phone using Tapatalk |
Video Slave 3 - How Stable? | TrentWilliams | Post - Surround - Video | 10 | 03-16-2017 06:41 AM |
WTB: Video Slave 3 Licence | TrentWilliams | Buy & Sell | 0 | 03-10-2017 09:33 PM |
Video Slave - Sync to PT | blizzard | Post - Surround - Video | 6 | 12-22-2013 01:28 PM |
midi machine control (slave) missing from peripheral setup | GStyle | Pro Tools M-Powered (Mac) | 0 | 04-12-2008 10:44 AM |
Reason as Rewire Slave Setup | asiabackpacker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-13-2004 09:49 PM |
