MBox Pro 2 - run w/ firewire only or with adapter
I understand that you can run the MBox Pro 2 with the firewire cable ONLY, with no need to plug in the power adapter. Does it run just fine without the power adapter or are those of you with the MBox notice that it performs better with the power adapter also connected?
Dave www.freis.us iMac 20" 2.16 Ghz Intel Core 2 Duo, 1.0gb RAM, OS X 10.4.9, MBox 2 Pro, Pro Tools 7.3 LE |
Re: MBox Pro 2 - run w/ firewire only or with adapter
Apparently not, as stated in the Mbox 2 Pro Getting Started Guide - DC Power "you should use external power if your 1394 bus is unable to provide enough power, or if you need to conserve battery power in a portable computer".
Although my Mbox 2 Pro has sufficient power to draw from (Desktop DAW) the DC Power supply runs 24/7 without a problem. filosofem
Aaron Mulqueen - 001 HD Native |
Also, although I can't speak for Mac users, having a 'Digidesign approved PCI FW Adapter' improved the overall performance of the Mbox 2 Pro. No H/W Buffer Size errors and External Clock (S/PDIF) Playback is 'more' stable, on PC's.
filosofem
MBox Pro and FireWire/Thunderbolt adapter | fonzi | macOS | 53 | 01-10-2018 04:02 PM |
AC adapter for Mbox Pro 3 Firewire | Billiam1959 | FireWire & USB Audio Interfaces (Mac) | 0 | 08-28-2013 12:28 PM |
Mbox 2 Pro - Firewire or power adapter? | ffernandes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-06-2010 08:29 AM |
Impossible to find SIIG FireWire 2-Port ExpressCard FireWire adapter | Bloody Maker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-22-2010 09:58 AM |
AC Adapter or Firewire? | wfasano | Pro Tools M-Powered (Mac) | 0 | 04-30-2009 09:06 AM |
