Old 01-20-2018, 11:26 PM
RogerPaolo RogerPaolo is offline
Default Soft keys right hand side not functional in Pro Tools
The soft keys for automation (right hand side) do not function properly in Pro Tools. They do in Logic, so this can not be hardware related I think.
If I change automation mode with [shift - Rec] the lights on the soft keys do reflect the automation mode the track is in, but pushing them changes nothing.
any idea?
Old 01-22-2018, 05:00 PM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: Soft keys right hand side not functional in Pro Tools
To change automation modes with the Right Softkeys on S3, you need to press and hold the automation mode you want to set and then select the track you want to apply that mode to. If you select Do to Selected or Do to All first it will do that too.
Old 01-22-2018, 11:24 PM
Thanks for your reply! That indeed did the trick. In logic the buttons work directly to the selected channel, I guess I expected the same behaviour in PT.
I also noticed that when faders are in a group and that group is selected the automation mode changes for that whole group.
Old 01-23-2018, 07:51 AM
Anthony_Anz Anthony_Anz is offline
It would be nice if the S3 worked like the Dock. Pressing the automation mode button will change the automation mode of the selected track(s).
Old 01-23-2018, 01:31 PM
That's how it works in Logic. pressing button 3 puts selected tracks in touch mode, as an example. To me that's more intuitive.
Old 01-24-2018, 05:44 AM
Cool!..
Soft Keys creativecontrol Avid S4/S6 8 12-18-2017 02:34 PM
Why no Soft Keys on S3? jacko Avid S1, S3, Dock and Control App 15 02-09-2016 07:43 PM
S6 modifier keys not functional after 2.0.1 update sauna-l Avid S4/S6 2 10-09-2015 12:15 AM
S6 fader module meters on left hand side? jacko Avid S4/S6 2 02-19-2015 04:04 AM
Side-chain keys, rdobra VENUE Live Sound Systems 4 03-31-2010 11:26 AM
