Old 10-01-2007, 01:36 AM
groovebrother groovebrother is offline
Default Error \"-4\" and 7100+ 7058 with MDW EQ on HD system
hi evryone,
first of all pardon me for my english that is "really not up to date" -
i would like to know if you guys had this problem. I have a G4 2x1G, 2G RAM, MacOS 10.4.9, PT 7.3.1cs4, all plugs are up to date.
The HW config is HD2 Accel + 4 Process Cards in a Magma PCI 64bit (P764-NE) + 192i/o.
I have tested the system with the cards back in the mac starting with the HD core then other cards one by one. It appears that the HD core generates error -4 then 7100 if one (or more), of its processors are busy with a MDW. It works fine on all other cards.
besides, since i bought the chassis, i have to turn off & on the 192 several times before it initializes correctly.
the errors come out when i make one or several tracks (with MDW on 'em), inactive then active, then it becomes impossible to work and i have to restart the system. But still, It is ok when the session lauches...
before testing the cards directly in the mac i had an error wich said somthing like " digital sync got suddenly disrupted" (don't remember the exact sentence), but there is no sync nor mptav nor synth plugged in digital form to the 192. So i presume the 192's clock may have a problem too. Then impossible to work the hole system gets stucked wich forces me to do a cold boot (hard boot ?).
i gess i need a little help here
thanks
Dominic
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 10-01-2007, 10:15 AM
DigiTechSupt's Avatar
Default Re: Error \"-4\" and 7100+ 7058 with MDW EQ on HD system
Do you get those errors when running Digitest or only when using MDW EQ? Which version of MDW do you have installed? Have you verified that ALL installed plug-ins are Pro Tools 7 compatible?
Avid Audio Tech Support
Support FAQ
Old 10-01-2007, 12:40 PM
ZEUSS ZEUSS is offline
I am getting this with the 5 band. Newest version MDW. Error 4. When loading a session. When it gets to where the MDW is inserted it happens. This is random as well. It doesnt always do this. When I restart PT the problem goes away. Have had this happen with cards in the computer and in a chassis.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 10-02-2007, 11:58 AM
nope the worst is that the digitest does not show anything (in "show all results" mode) - it goes bad only with the MDW 3or 5 bands in the session while making tracks inactive/active -
yes the MDW EQ is up to date as all the software & OS as recomended by Digi
I can also add that, if the session is not stucked, i still can recall the MDW & make it active from the plugs menu where the DAE error 7058 appears.
My soundcloud page
Old 10-04-2007, 04:59 AM
hello Zeus,
do you still have your problem ?
My soundcloud page
Old 10-04-2007, 10:18 AM
Can you give me the exact steps you are using to recreate the problem? I tried inserting it and then activating/deactivating the track, but could not get an error to occur....
Ideally, if you can create a session that only contains the MDW EQ and get this to occur, we'd like it if you could send us the session file to transfer [at] digidesign [dot] com. Reference this DUC thread number (1204534) in the subject of the message.
Support FAQ
Old 10-04-2007, 10:47 AM
sure, just give me a few minutes, i kept the session i did the test with.
all right, the material have been send to David D. , he should get in touch w/ya soon...
My soundcloud page
Old 10-05-2007, 10:27 AM
hi,
Have you recived the session ?
My soundcloud page
DAE error -7058 syMPh Pro Tools TDM Systems (Mac) 4 06-22-2010 03:18 PM
DAE Error 7101 and 7100 on Mix system Hive Guy Pro Tools TDM Systems (Mac) 0 12-22-2006 12:26 PM
Error 7100 and Error 4, tracks have no voices help WannabeSQ Pro Tools TDM Systems (Mac) 1 08-10-2006 02:24 AM
error#4 and error #7100, pro tools crash! audioluche Pro Tools TDM Systems (Mac) 2 06-19-2006 06:10 AM
DAE error 7058 with Amp Farm on new HD 2 Accel belouder Pro Tools TDM Systems (Win) 3 01-31-2006 01:10 AM
