Old 02-21-2019, 02:25 AM
Raemond Cook's Avatar
Raemond Cook Raemond Cook is offline
Default Re: Avid Sync I\O
Have tried different combinations od routing output with the the correct xlr cables, have routed 1\2 to 7\8 as per user setup manual and also external audio source (Computer\Itunes) 5\6 and my Ipad\Iphone is routed through 3\4 is routed via input 2 and works perfectly (get audio output) but nothing from PT, any other audio output except PT produces audio output
Old 02-21-2019, 02:33 AM
Meads Meads is offline
If signal goes to the interface but not the monitors it is a wiring/routing issue.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 02-21-2019, 02:57 AM
Or worse case scenario its the output card on the 192 thats has an issue, as like I have stated I have tried several multiple options to get audio from PT into PC and to monitoring system, and as previous all other audio sources connected to Input 2 on the PC work fines get audio from PC outpour 3 to monitoring system. So not a wiring\xlr cable routing issue
Avid Sync IO HDXSound Pro Tools 12 20 05-30-2017 04:53 AM
Avid Sync HD with Aja Gen10 TVPostSound Buy & Sell 2 10-29-2016 09:39 AM
sync to Avid Scratch rafukyo Pro Tools TDM Systems (Mac) 1 02-11-2010 04:12 AM
omf avid to pt: sync slippage c-post Post - Surround - Video 6 02-16-2002 10:34 AM
AVID / PT sync - Help Iamrod Pro Tools TDM Systems (Mac) 3 05-17-2001 01:33 PM
