Question for GURU about Pro Tools Inserts
I have a Question for the Pro Tools GURU about Inserts
I just trash all my Pref I start a new session with just the minimum but it`s still say that I have inserts in 1-2 and 21 - 22 Can someone explaine that one to me Thanks for your time See Attachement
Your eyes can deceive you don't trust them , Mix with your ears |
Re: Question for GURU about Pro Tools Inserts
Never mind I got it
bookerv12 |
A strange thing happends to me. I have output 8 connected to an external RTA, but I cant use the in/out 7 as an insert unless I inactivate out 8. I would have to modify I/O and turn 7-8 stereo path into mono paths to work.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
I/O setup isn't in Prefs. It's a different file. If you have "Last Used" selected when you start a new session, that's what will show up. Namaste.
Mark Ettel C.A.S. |
just speculating but perhaps PT loaded ""last used" I/O option when creating a new session. adding perhaps PT remembers this even with a trash preferences procedure.....
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
RegEx-guru question | Frank Kruse | Post - Surround - Video | 9 | 04-25-2018 04:55 PM |
Pro Tools HD inserts question | jrmintz | macOS | 2 | 09-10-2013 12:49 AM |
A question for a wiring guru. | IO Composer | Post - Surround - Video | 3 | 08-06-2004 04:30 PM |
Question for midi guru old timers | Donny | MIDI | 1 | 02-21-2004 06:52 PM |
A Midi question for a Guru | clarpark | Pro Tools TDM Systems (Mac) | 3 | 02-22-2003 04:10 PM |
