Old 11-29-2013, 03:19 PM
BLUNTBRAD BLUNTBRAD is offline
Default c/24/s6/Eucon
So I'm getting ready in the next few months, to build a top of the line, HDX studio. I thought i would need a C/24 console. From reading the different forums, sounds like it isn't the way to go for the future. I never even heard of a Eucon, till i hit the forum. What is the Pro Tools console of the future?
Old 11-29-2013, 03:43 PM
Default Re: c/24/s6/Eucon
It is hard to predict the future but the new technology is the S6. The C|24 is fairly old.
Not hitting on the C|24, but it is unlikely to be powering many "top of the line HDX studios" today, they'll more likely to be running things like the Icon D-Control ES. The S6 seems capable of spanning the C|24 to Icon space and more. Maybe better at the lower-end if Avid change bundle/entry point options.
Old 11-30-2013, 08:49 AM
Brandonx1 Brandonx1 is offline
What's your budget and what type of projects do you work on?
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 11-30-2013, 10:11 AM
Wow, i had no idea those other consoles cost 80,000-150,000. I want to be able to produce, mix, and master Hip hop, R & B, and Pop music, at the highest level possible, that is Radio ready. HD system. Budget is between 20,000-40,000 preferable over a few months, where i can get started 10,000 to 15,000 and add on as needed
Old 11-30-2013, 10:33 AM
That budget is for the control surface only or for the HDX cards and interfaces as well? Do you have DAW computer(s), studio monitors, preamps, mics, cabling, all the other studio gear as well or are you mixing only not tracking?
Old 11-30-2013, 01:56 PM
Emcha_audio's Avatar
Hi there BluntBrad
Unless you're ready to also invest in quality mastering tools you won't be doing a one stop shop as you think you will, not with that budget anyhow.
Also let's be honest, even if the C|24 was to be discontinued this year or next year there will still be a support time of at least 5 years, which if you plan your business carefully and put a percentage of the gross income aside for future upgrade, you will be fine. As a controller (if you forgo the C|24 as the monitoring system), it is very well implemented for HD use and it has been used in many medium spaced professional studios, even if it's aged it's still very functional even today.
So if you look carefully at the deals you will be able to get a C|24 and a HDX system with interface for roughly 25k taxes included. Then all that you need to do is push on to your monitoring system and space treatment, mics and cabling with the rest of the budget, upgrading these as you go in the future.
On the other hand you could very well just spend it on a 8 faders 5 knob S6 m10 and a hdx card with I/O, which will bring you to around 35k and you can then move to upgrading the s6 from there on.
C|24 bundled with HDX and I/O From sweetwater. Check around there are other examples.
Manny.
https://wn.nr/JWU7cA
Old 11-30-2013, 06:04 PM
OK, FOR THE S6. How do you know 35,000? Has it been released? How do you know the pricing? Can everything done on the c/24, be done on this new s6?
Old 11-30-2013, 07:50 PM
NO not everything can be done on the C|24 than on the s6, because the s6 came after and is will have new things added, whereof the C|24 development has been done for a while ago. I do know because the prices were announced publicly, but then for some reason they were taken out. Anyhow the starting unit would be around 21k for the s6, that's 8 faders, 5 knobs, the touchscreen/brain and the automation module.
Manny.
Old 11-30-2013, 10:04 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
There'll probably soon be some great deals on used Icons or C-24s and the S3 is probably going to morph into a mix controller from its current live sound role. Everything is really in flux right now because 11 is the biggest change under the hood to Pro Tools in nearly 20 years.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 11-30-2013, 10:06 PM
Pound some transport button onto an S3 and I'll take one
Eucon Windows BUG: some windows r stuck in background when Eucon running. TuckerMix Artist Series 12 07-08-2014 02:37 PM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 01:01 PM
EuCon 2.5.7 now available DigiTechSupt Artist Series 0 03-10-2011 12:09 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 11:25 PM
Eucon and PT HD 9 soundworx Pro Tools TDM Systems (Mac) 2 10-26-2010 11:42 AM
