Old 05-13-2012, 11:39 AM
gereon gereon is offline
Default Assertion in "..\Mdie_TrackPlayer.cpp" line476
good day. can someone help me what is this? i can't open my project anymore. and that is the message of the error... thank you
Old 05-13-2012, 07:26 PM
Craig F Craig F is offline
Default Re: Assertion in "..\Mdie_TrackPlayer.cpp" line476
start here
http://duc.avid.com/showthread.php?t=193634
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 05-13-2012, 09:12 PM
soybalm soybalm is offline
I found this bug by using the notation display and moving a few notes. I found by closing Pro Tools and restarting it, it fixes the problem. I just can't move notes around. The midi editor is fine although that can cause some graphic freezes. I don't know what causes the Mdie line476 error but I already started a thread but had little response.
I used Win 7 on a 64 bit Gateway but the video card is a Quadra 600
Craig F was suggesting to use a Sandra report which may give more helpful details about your setup. I think it's overkill but in some cases it does help.
Old 05-27-2012, 05:05 AM
SiSoftware Sandra
ID
Host Name : David
Workgroup : WORKGROUP
Computer
Model : Gateway LX6810-01 To Be Filled By O.E.M.
Serial Number : PTG590X001849073192700
Chassis : Gateway Desktop
Mainboard : Gateway FMCP7AM
Serial Number : U00P084807326
BIOS : AMI (OEM) R01-A1C0 07/17/2009
Total Memory : 8GB DIMM DDR2
Processors
Processor : Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz (4C 2.33GHz, 2x 2MB L2)
Chipset
Memory Controller : Acer MCP79 Host Bridge 4x 333MHz (1.33GHz) FSB, 8GB DIMM DDR2 2x 400MHz (800MHz)
Memory Module(s)
Memory Module : 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3)
Video System
Video Adapter : NVIDIA Quadro 600 (96 SM5.0 1.28GHz, 1GB 1.59GHz, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA Quadro 600 (96SP 2C 1.28GHz, 1GB 1.59GHz)
Compute Shader Processor : NVIDIA Quadro 600 (96SP 1.28GHz, 1GB 1.59GHz)
Storage Devices
WDC WD6400AAKS-22A7B0 (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 596GB (C:)
Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm) : 1TB (E:) (F:) (G:)
Maxtor 6B250S0 (251GB, SATA150, 16MB Cache) : 234GB (M:)
Lexmark USB Mass Storage (USB2) : N/A (L:)
Generic- Compact Flash (USB2) : N/A (I:)
Generic- SM/xD-Picture (USB2) : N/A (K:)
Generic- SD/MMC (USB2) : N/A (N:)
Generic- MS/MS-Pro (USB2) : N/A (R:)
HL-DT-STDVDRAM GH15F (RAID, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (P:)
ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (Q:)
Logical Storage Devices
OS (C:) : 582GB (NTFS) @ WDC WD6400AAKS-22A7B0 (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache)
bigmax (M:) : 234GB (NTFS) @ Maxtor 6B250S0 (251GB, SATA150, 16MB Cache)
seagate 1 (E:) : 479GB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm)
seagate 2 (F:) : 288GB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm)
seagate 3 (G:) : 383GB (NTFS) @ Seagate ST31500341AS (1.5TB, SATA300, 3.5", 7200rpm)
PQSERVICE : 15GB (NTFS)
Removable Drive (L:) : N/A @ Lexmark USB Mass Storage (USB2)
Removable Drive (I:) : N/A @ Generic- Compact Flash (USB2)
Removable Drive (K:) : N/A @ Generic- SM/xD-Picture (USB2)
Removable Drive (N:) : N/A @ Generic- SD/MMC (USB2)
Removable Drive (R:) : N/A @ Generic- MS/MS-Pro (USB2)
Optical Drive (D:) : N/A @ HL-DT-STDVDRAM GH15F (RAID, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (P:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache)
Optical Drive (Q:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache)
Peripherals
LPC Hub Controller 1 : Acer GeForce 9400/9300/9200/nForce 730i (MCP79) LPC Bridge
LPC Legacy Controller 1 : ITE IT8718F
Audio Device : Acer MCP79 High Definition Audio
Audio Codec : Realtek Semi 888 High Definition Audio
Audio Device : VIA M-Audio Delta AP192
Disk Controller : Acer MCP79 Memory Controller
Disk Controller : Acer MCP79 RAID Controller
USB Controller 1 : Acer MCP79 OHCI USB 1.1 Controller
USB Controller 2 : Acer MCP79 EHCI USB 2.0 Controller
USB Controller 3 : nVidia MCP79 OHCI USB 1.1 Controller
USB Controller 4 : nVidia MCP79 EHCI USB 2.0 Controller
FireWire/1394 Controller 1 : Acer IEEE 1394 Host Controller
SMBus/i2c Controller 1 : nVidia MCP5 SMBus 1
SMBus/i2c Controller 2 : nVidia MCP5 SMBus 2
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Lexmark S600 Series (4800x4800, USB, Colour, Duplex)
Printer : Lexmark S600 Series (4800x4800, Colour, Duplex)
Printer : Lexmark S600 Series (600x600, USB, Colour, Duplex)
Scanners and Cameras
Scanner : Lexmark S600 Series (Scanner, 600x600, USB)
Peripherals
Network Services
Network Adapter : NVIDIA nForce 10/100/1000 Mbps Ethernet (Ethernet, 100Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Strange "Assertion" error causing Pro Tools to quit unexpectedly...???? nickbradbury macOS 13 09-10-2014 04:50 AM
Help for Error Message - Assertion in "..\Mdie_TrackPlayer.cpp", line 476 lbpease Pro Tools 10 7 01-05-2014 01:15 PM
assertion in "..\Mdie_TrackPlayer.cpp", line 469 / access violation/ DAE error -9400 thibault 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-22-2013 06:08 PM
Could not complete the Open Session..command Assertion "KeyContextRegistry" line72 JLiRD808 Windows 4 12-25-2012 02:01 PM
Error: "pro tools could not complete the import audio command because assertion in" elsterNJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 10:38 AM
