Okay, I'm officially confused on using the new feature of audio to midi with the Melodyne Essential plugin added as a freebie with 2020.11
I've had Melodyne 4 ever since it came out, but never upgraded to 5. My Avid products page provides me the code to unlock Melodyne Essential 5. However, the "Loyalty Rewards" tab that supposedly has the link to get it is completely missing on my products page. It showed up briefly and then just disappeared! In PT, if I search for Melodyne I can see Melodyne 4, which I've had, and then one that just says "Melodyne'. Is that new one? If I try to install that, it opens a Melodyne page to update to 5.1. But I don't see anywhere I'm supposed to input the code I got from Avid. And none of it looks like the example is the screen shots given on the instructions page provided by Avid on the my products page. I couldn't be more confused! ![]() ![]() ![]() ![]() ![]()
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC Dell XPS 435T/9000 Win-10 Pro 24gig RAM IntelCore i7 CPU 920@2.67GHz Pro Tools 2019.10 Focusrite Scarlett 8i6 |
Never mind. I think I just discovered the answer. Apparently you have to first remove any version of Melodyne 5.0 or earlier you have on your system BEFORE installing the new 2020.11 update.
Keep v4 I still use V3.2 for standalone for the midi control features
The audio to midi in pro tools 20.11 works fast. Give it a try. You can put back the v4 plugin. OS 10.14.6 2010 cMP 12 core
(Help us Help You)<<<click here Last edited by DetroitT; 11-14-2020 at 03:41 PM. Reason: correction V3.222 |
I have just seen in the celemony shop that you can use the essential serial number as a coupon to get a discount of 49 € when I upgrade my Version 4 to 5
Ale
PT HD Ultimate 2020.11 6/12-Core Westmere/ 48 GB / OS 10.13.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2020.11 / MacMini Server late2011 / 16 GB / OS 10.13.6 / 002 |
![]() Quote:
I thought that might be the case, but I can't find that info on my account anywhere on the Celemony website.
![]() Quote:
All I've done at this point is uninstall it. Now the Audio to MIDI feature works as advertised in PT. And you're right, it is fast. However, I do notice some differences. For example with a drum loop, it put the entire beat on one note. Whereas in 4 with the percussion algorithm it broke it out to different notes, like a MIDI drum track would. Maybe there's another way to do it? One of the main things I like about the audio to MIDI feature in Melodyne is being able to take a basic drum loop, convert to MIDI and change up the drums being used. Is there a way to do that using the new feature? I had no issues with a synth bass part or a lead synth line using the "melodic" algorithm.
![]() Quote:
Hi Donald, did you try using the polyphonic setting? Just my guess that poly might split the drums to different pitches. Sent from my iPhone using Tapatalk Pro |
![]() Quote:
I wasn't planning on upgrading to V5 Studio which normally costs €149 however e.g. if the price drops for Black Friday, it might be worth it just for the housekeeping and to avoid complexity within PT. What's the process to get the €49 discount - should I add the new V5 Essential license to my Celemony account, or is this part of the checkout process? |
![]() Quote:
PT 2020.12 DP 10.13 MOTU M4 HP Envy 8G i7 Quad Laptop Win10 PT 2020.12 DP 10.13 828mkII ADA8200 MTP-AV HP Z2 G4 Xeon Workstation Win10 2011 Mac Mini i7 Quad High Sierra.6 VEP 7.x hosting various VIs Last edited by ChuckS; 11-16-2020 at 07:37 AM. |
FS: Melodyne 4 Essential - 39$ | domagtom | Buy & Sell | 3 | 10-05-2019 12:48 PM |
FS: Melodyne Essential $75 | ramune64 | Buy & Sell | 2 | 07-09-2018 06:23 PM |
Melodyne Essential, that came with PT 8.0 | tchambeau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 25 | 12-30-2010 11:29 PM |
Melodyne Essential 2.0 | DonaldM | Virtual Instruments | 2 | 11-23-2009 05:05 PM |
Melodyne essential... | whit12 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-01-2009 05:31 PM |
