  #31
Old 08-25-2017, 11:50 AM
EddieJones's Avatar
Default Re: New Avid S3 constant failing faders. ASC throws Visualforce error
I Just heard the engineer has successfully removed the code that flags the false errors so definitely going to check it Monday. This does also remove the real errors but S6 doesn't even have this and its pretty obvious when a fader goes bad.
This will be in v3.8 later this year but I can sort anyone who needs a beta in the meantime.
  #32
Old 08-28-2017, 05:39 AM
The Saxplayer The Saxplayer is offline
Hello,
I will gladly test the beta for you!
[email protected]
Thanks for your efforts!
Cheers
Georges
Thanks very much
Georges
The Saxplayer
  #33
Old 09-03-2017, 02:59 AM
Parallel to this discussion I am also talking to support via my Avid Dealer
(Amptec Belgium, great guys to work with)
On their recommendation I swapped fader 3 & 16 and for now it seems both faders are doing their job and we are not getting any error messages.
I'll post further developments here.
Kind Regards
Georges
Thanks very much
Georges
The Saxplayer
  #34
Old 09-11-2017, 03:44 AM
So far no changes. All 16 faders work without any noticeable glitch. My best guess is that we are talking about fader manufacturing tolerances.
I doubt that we are talking about bad contacts. The multipin is rather well made and clicks in properly.
Thanks very much
Georges
The Saxplayer
  #35
Old 09-25-2017, 06:37 PM
tek720 tek720 is offline
I have 6 S3's, they are used 60-70hrs a week. Unfortunately Avid has used the same faders since the Command 8. If Eucon says its failing, and your mouse cord isn't jamming it, it's the physical fader. They take about 15-20min to replace.
  #36
Old 09-27-2017, 01:53 PM
EddieJones's Avatar
This is not true, we found something in software that was throwing false negatives. This has been fixed in v3.7. Also we use many different faders and different revisions in our surfaces. The manufactures generally make them better over time. Whilst it may be the same manufacturer its not the same fader.
  #37
Old 10-02-2017, 01:53 AM
alvarodeiscar alvarodeiscar is offline
Hi Eddie,
Glad to hear that Avid is working on this...
Several problems with s3 here too....
My (short) history:
Spanish Post facility, 2015 we bought 3 s3. 3 moths later, two of them sent back to Ireland to repair, (both with fader failure message and not recovering after the rest in eucon soft)
the third one sent back a few moths later... All the three broken... (I suppose) as Avid dint really told us was what wrong with them!
After update to eucon 3.6.1, had fails with disconnection of the console. The mixer was aparently working but faders dindnt work and menus didn't work either! It was a freeze of the s3.... thinking on sending it to Ireland again, but I downgraded to 3.6 and suddenly stop this fail....
Want to say that the machine was deleted and reinstalled from gound several times and the failure was still there...
My conclusion is that, if its a software problem, we still have some chance to get this solved...
I hope your team gets into the real problem!
Following this thread BTW...
  #38
Old 10-02-2017, 12:31 PM
EddieJones's Avatar
Originally Posted by alvarodeiscar View Post
Hi Eddie,
My (short) history:
Hi, sorry for your issues. I doubt its a problem with software between 3.6.0 and 3.6.1 as I haven't heard this for other users and would notice it here.
When you say the S3 freezes, what is displayed on the OLED's, also is the S3 still listed in the Connected surfaces tab of EuControl ? Is this happening with all 3 S3's ?
  #39
Old 10-05-2017, 01:35 PM
khoop2112 khoop2112 is offline
Having same problem here....any resolution?
  #40
Old 10-05-2017, 01:46 PM
EddieJones's Avatar
Yes in v3.7 on the 18th Oct
Avid Artist Community "Visualforce" error Airehnr66 General Discussion 0 04-04-2016 04:58 PM
Avid Profile Fader Bay Circuit Boards failing [email protected] VENUE Live Sound Systems 1 12-13-2015 11:07 PM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
What's the fix for a session that throws this message? albee1952 Pro Tools 10 2 06-05-2014 11:09 AM
Faders failing on some sessions lyoung1101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2007 11:55 AM
