Structure Beta doesn\'t fit my screen.
Hello all,
I finally got to run my beta here and the first thing I've found is that the sample edit window does not size to my iBook screen size. The bottom and the right side of the edit window are just cut off, but it doesn't seem that I can get to the resizing functions at all. Any tips? iBook G4 1.42 M-powered v.7.3.1cs Firewire 410 Triton LE Thanks! wolfdavis
Justin Davis Rocky Mountain Recorders |
Re: Structure Beta doesn\'t fit my screen.
hopefully that will be something they look into for the final version..
my only suggestion is to adjust your resolution and slide the edit window over as far left as possible..? i'm using a widescreen, but even at 1440x900 the edit window opens halfway off of my screen, so i definitely hear ya.
Drum and Bass sounds better with Pro Tools |
Thanks for the thought, but I'm at the highest res my screen can manage. I am probably going to have to add a second monitor to my system to get at the rest of the window. The problem with this is that I get much less power out of my little iBook. (Awh, ain't it cute.)
If there are any fixes that have been released to this part of the beta I would love to know about them.
Which iBook model is this and what is your screen resolution set to?
It dosen't fit my screen either.
the bottom get's cut off. IBM G72 1024 x 768, 85 Hz, Millions. Mac G5 dual 200ghz, Two Monitors, 1.5 Gig, OSX 10.4.9, two internal Barracuda's Le 002, 7.3.1cs2 Music Production Toolkit. Frequently Crashes my session, all by itself, 1 Track. uses more than half of my CPU, with only One Patch Loaded. Good Luck! God Bless!!!! |
I'm on a 1.42Ghz iBook PPC.
The res is set to 1024x768 (the highest setting) After having messed with it a bit I got it to show almost the entire plug screen, but it still chops off the right edge and the very bottom. It is usable, but sometimes frustrating. Thanks, wolfdavis
AIR, Drop Everything! We Need Structure Out of Beta! | relaxo | Virtual Instruments | 34 | 03-01-2009 09:38 AM |
Structure beta to purchased version. | TravisDRS | Virtual Instruments | 3 | 08-25-2007 03:27 PM |
Structure Public Beta - Thank you | Wolfram K | Virtual Instruments | 5 | 06-18-2007 09:48 AM |
Digidesign Structure now public beta | Majorek | Virtual Instruments | 1 | 04-05-2007 10:11 AM |
How to point Structure to Beta Patches | AG | Virtual Instruments | 3 | 03-13-2007 07:01 PM |
