connecting presonus firestation to digi 002
Hello everyone,
A couple of years ago i bought a presonus firestation to use as an adat i/o with my digi 002. For some reason it never worked. - Does anyone have an idea how to connect the units.? - Do i need drivers and if so which ones? Please let me know Regards, Kenneth |
Re: connecting presonus firestation to digi 002
Right now i'm using a mac pro running protools 7.4
connect the two using two Optical cables. You then need to change in your hardware preferences the master clock to external Optical. Lastly you need to go into your I/O setup and makes sure that you create 8 new inputs routed to 9-16. You should then have your 8 analog inputs of the 002 for 1-8 and the 8 digital inputs or ADAT inputs for 9-16. That should get you started if the Presonus is functioning properly.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9 |
ps- no drivers needed
I already tried this. When I select optical as a clock source in protools it says that it's " no valid clock source " and the reverts to internal again. It seems that protools isn't able to see my firestation.
Yes I have. I've read the instruction manual and connected evertything as it should be. And still nothing.
Bad lightpipe "cable"?? Or either or both ends not fully seated as those "connectors" are not the best ever.
Presonus Firestation??? | nukmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-29-2003 09:22 AM |
Anyone Using Presonus FIREstation? | brinaddison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-29-2003 09:55 AM |
Presonus Firestation | Pete Evick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-17-2003 03:48 PM |
Presonus Firestation | mjteix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-19-2003 01:18 PM |
Presonus FIREstation | Mark_Knecht | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-05-2002 04:23 PM |
