Re: Pro Tools 11 on mac not showing waveforms
Are you on HD? Does it matter? is this a "global" Pro Tools bug?
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Yes, running 11.2 HD. Not sure if it matters or not, but I hope you get your situation resolved soon.
Chris |
In my (naive) excitement, I uninstalled PT V10. How can I get it back?
I'll have to use V10 for sequencing, recording and editing, and use V11 for mixing only. I need to see the waveforms! How can I get back V10?
By downloading the installer again from your Avid account ?
By re-installing with the already downloaded installer, that you kept for safety ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
I didn't keep a "Safety". I'll have to larn that now. Will the new iLok work?
#16
I have the bundled PT10/11/HD licence on my 2nd Gen iLok, and both PT 10 and 11 work with it.
#17
.... but Maverics doesn't support V 10 .... *scratch head*
#18
1) Today, I received a session which was recorded in V 10, from a client. I opened it in V 11, and the audio waveforms showed up!
2) I created a new mix session and imported the session data from the client's session, but the audio didn't show up. 3) I created a new video session, imported a video clip that I shot on an iPhone, and the audio from that showed up. 4) I imported another video clip, rendered in Final Cut Pro X, and the audio didn't show up. Any ideas?
#19
UPDATE:
When I import and audio, I can re-record it internally, to another audio track, THEN the wave forms show up! Recording audio from the Pro Tools synth is not a problem. I have to try it with third party synths next.
#20
If you are importing from an external hard drive the issue you are having is due to the hard drive not being able to process fast enough to Pro Tools 11. I had the same issue. What I did to fix this was make a folder on the physical hard drive called " Pro Tools Imports" you can name it what you want of course and then I proceed to always add the files I want to import into my session in that folder. Import from this folder on your physical hard drive or any other folder on the physical hard drive and this issue is resolved. I hope this helps you!
Waveforms not showing when recording | Dizzi45Z | Pro Tools 10 | 3 | 10-29-2015 11:10 PM |
PT 8 not showing waveforms | crypt0r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 11-08-2011 07:31 PM |
Pro Tools 9 Waveforms | firebass305 | Pro Tools 9 | 10 | 11-19-2010 11:09 AM |
Pro Tools not showing waveforms (in centre) | TheBeats | Pro Tools M-Powered (Win) | 1 | 12-12-2009 09:22 PM |
No Waveforms showing when I use Rewire | essplode | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-17-2008 09:35 AM |
