S4 not recognizing new computer
Hi all,
Looking for a little help getting my S4 and new M1 Mac Studio to talk to each other after replacing a 9 year old Mac tower. The Mac is brand new, running Ventura, and I'm using WSControl 2021.10.1.29. I see there is a new version of WSControl out, but it's not visible in My Product Info and it's not in the Avid Download Center. WSControl also has a triangle/exclamation point sign in the icon at the top of the screen. I suspect that updating WSC will help but I have no idea how to locate the new version for download. As for the S4 itself, it is connected and configured the same way it's always been. I manually entered the same IP address that the S4 is accustomed to using. But under the Workstations tab on the master module, no computers appear under "network" and no workstations appear under "connected". Thanks for hearing me out! |
Re: S4 not recognizing new computer
Greetings,
Ventura support for EUCON began with v 2022.12: https://avid.secure.force.com/pkb/ar...-Compatibility Ensure that both WSControl on the workstation and the S4S6MasterModule Software have identical versions installed. If your support has lapsed on your S4 you would need to connect with your reseller to get updated coverage so you can grab the latest S4 S6 software from your account. best, Jeff |
Also, where did you manually enter the IP address? Are you using the S6 as the DHCP server(Surface settings)? If so, don't manually assign an address.
Did you do a migrate to the new MAC, you may need to rename the computer and restart it (Apple bug) |
Thanks guys. I changed my computer's network setting to DHCP for that ethernet port. My Network Interface 1 is set to DHCP. #2 is set to aa specified IP address. My network page in system prefs has a green light on the ethernet that is connected to the board. WSControl has a new name for the new computer next to "ID". Is there anywhere else I should rename the computer? WSControl has nothing next to "warning" but it also doesn't say "connected".
The "Workstations" page has nothing available under "Network" and nothing listed under "Connected". I hope I'm not at the end of the road... I have a call out to an Avid rep for a support contract but haven't heard back yet. Thanks again for your help! |
On the MTM network settings. Whatever port is connected to the S6 (should be 1) that should have the static IP set and DHCP server checked on. The other one (2) should be set to DHCP in the Drop down and the check box off. The lead from the S6 switch to the Mac should go direct and not through any other network switch/router.
Please Hi please I need help, my computer is not recognizing 11r as audio interface | BetoRock | Eleven Rack | 2 | 03-08-2014 09:47 AM |
Computer not recognizing 002r | nczeke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-14-2010 07:45 PM |
My Computer is not recognizing my Mbox 2. What to do? | Percept26 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-10-2010 12:53 PM |
New Computer Not Recognizing Plug-Ins | bigcow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-15-2008 02:41 PM |
Computer is not recognizing my digi 002 rack | mtausch11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-26-2005 08:57 AM |
