Old 02-08-2011, 12:50 PM
Onager1286 Onager1286 is offline
Default Does Pro Tools benefit from multi-core CPUs?
Just as the title says, I was wondering if Pro Tools scales well with more cores. Right now I'm running an AMD Phenom II 720, a 3-core processor, at 2.8 GHz. It's been pretty spritely but then again, I really haven't run any truly large sessions on it, and when I load on the virtual instruments like Kontakt and Kore, it can choke up a bit at lower buffer levels.
With everyone getting so excited about Sandy Bridge, I feel like it's easy to forget that AMD's Bulldozer is right around the corner. And Bulldozer will likely put a powerful 6-core processor out. So would it be worth it to go for more cores, or is clock speed more important for audio processes?
Old 02-08-2011, 01:00 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Does Pro Tools benefit from multi-core CPUs?
Yes. I m running six physical cores and have 12 multicores.
To see how the different processors perform, here is a Mac example:
http://www.primatelabs.ca/geekbench/mac-benchmarks/
Which is most important depends on your sessions. But performance wise you see a six core running close to an 8 core since the 6 is faster.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 02-09-2011, 02:04 PM
Interesting, thanks for the help. Is anyone else thinking about AMD solutions or is everyone pretty much Intel?
Old 02-09-2011, 02:52 PM
sunburst79 sunburst79 is offline
The more cores the better.
Dump a 199.00 X6 HT1055 in there.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-09-2011, 02:53 PM
Back in the days of Windows XP, PT7.x, and using two dual-core AMD server class Opterons, that was the Quadzilla beast and Intel was lagging behind. For the last 2-3 years however Intel is leading the performance race with the Core2Duo, Core2Quad and now the i3, i5, i7 processors. We live in interesting times indeed.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.15.2 running Protools 2019.12.0
Old 02-09-2011, 03:39 PM
Late 2006. It's been like 5 years already.
It does seem like yesterday however.
Scott
Core 2 Specs Page
Old 02-09-2011, 07:36 PM
Ah yes, and it was PT7 that was the first version to work with multiple cores
Old 02-28-2012, 09:20 PM
qtheproducer qtheproducer is offline
I apologize for resurrecting an old thread but I have a question....
How many cores can pro tools support on PT 10?
The reason I ask is because I am about to purchase a i7-3930k processor and a lga 2011 socket motherboard...
The i7-3930k is a six-core cpu/ 12 threads. I am wondering if PT 10 will take full advantage of all my cores/threads..???
Old 02-28-2012, 10:14 PM
CME CME is offline
Default
You'll be on the bleeding edge with that build, but yes pro tools will see and use as many cores as you can give it.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 02-28-2012, 10:55 PM
The bleeding edge? Is that a good thing or a bad thing CME?
http://en.wikipedia.org/wiki/Bleeding_edge_technology
According to that article it can be good , but then again, it can be bad
[IMG] code is Off
Performance of Pro Tools in multi cores seems the same as in single core whsi Windows 5 02-10-2014 09:58 PM
does pro tools MP9 support multi core cpus. ? thecherish@gmail.com Pro Tools M-Powered (Win) 1 05-28-2012 06:25 AM
hyper-threading in Mac cpus - can Pro Tools use it? SixChurchStreet macOS 4 02-11-2011 09:55 AM
Pro Tools LE multi-core support mikefatom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-22-2008 10:24 PM
Any Benefit to get a G5 quad over a G5 dual core? Daniel_Dettwiler Pro Tools TDM Systems (Mac) 4 01-03-2006 07:07 PM
