Old 05-15-2020, 09:10 PM
anguswoodhead's Avatar
anguswoodhead anguswoodhead is offline
Default HD10 mountain lion Mac Pro 5,1 not working
HD8 was running fine
Installed HD10
Got this error
So I upgraded to Mountain Lion 10.8.5
Still got the same issue
Any help appreciated.
https://www.glasshousestudios.com.au
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
Pro Tools Ultimate 2023.12
HDX card
AVID TB3 1 slot PCie Chassis
Old 05-15-2020, 11:28 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: HD10 mountain lion Mac Pro 5,1 not working
Can’t see the pics, I had nothing but love for 10.8.5, that was a great release.
I ran PT10.7 on it for several years without issue
Daniel
Old 05-16-2020, 01:55 AM
crizdee's Avatar
crizdee crizdee is offline
Installed HD10
Got this error
Did you uninstall PT 8 before attempting to install PT10.
You should use the uninstaller that comes with the version you want to uninstall so you should run the uninstaller for PT8 HD.
Complete uninstall. Repair disk permissions. Reboot. Reinstall.
What OS were you running with PT 8?
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-12-2020, 07:42 PM
s.d. finley s.d. finley is offline
that combo should work like a dream. I would wipe the HD clean and do fresh installs all around. Sure its a PITA but it is going to work wonderfully afterwards
sdf
www.sugarhillstudios713.com
Old 07-08-2020, 06:22 AM
groovebrother groovebrother is offline
agreed, clean installs are the best way ever.
It can also work like a charm on Mavericks - i Just move to it last month after years using 10.6.8 & 10.8.5
no issues at all
but always after clean install
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 09-09-2020, 09:09 PM
Sugarnutz Sugarnutz is offline
I'm sussing out Mavericks for a buddy in Nashville on PT10 Vanilla with a Mac Pro 3.1 and I installed PT 10.3.8 which is what I had handy (my license is for HD). So far I hooked my Zen Studio+ up via USB to replicate his setup sorta since I'm HD5 TDM in a Magma for this Mac Pro (sadly no Thunderbolt on a Cheesegrater) and I'm starting to dig it. I'm finding some of my VIs & plugins are compatible with Mavericks but not ML. I recorded 24 mono tracks and then played those back recording 24 more and never got over 10-11% CPU with no issues at 128 buffer, did both recordings for over an hour. Now my Mac Pro is a 2008 3.2GHz 8-core with 32Gb of RAM and SSDs for the OS, not sure what my buddy has yet but it will be the same when I'm done.
In a week or two I will hook my Magma/HD 5 up and redo some torture testing to make sure it all works for me and I will respond back if there are any issues.
Old 09-10-2020, 12:32 AM
There is no PT 10.8.3, last version would be 10.3.10
Old 09-10-2020, 12:05 PM
Sorry. I got dyslexic there for a sec, it's 10.3.8 (Pro_Tools_10_3_8_Installer_80777).
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Mapping Keyboard Shortcuts in Mountain Lion Not Working cuttothebeat Pro Tools 11 0 12-02-2013 02:28 AM
MBox mountain lion drivers not working DelChivo macOS 16 11-03-2013 04:48 PM
10.3.6 not working in mountain lion 8.4 mortenbrekke Pro Tools 10 5 06-26-2013 12:00 PM
Lexicon PCM Native Reverb and Mountain Lion-Working? Will Russell Pro Tools TDM Systems (Mac) 7 09-11-2012 08:25 AM
Pro Tools 10.2 HD Native on Mountain Lion, Successfully working! saproduction Pro Tools TDM Systems (Mac) 11 08-24-2012 02:32 PM
