Old 03-27-2017, 08:19 AM
DJ Hellfire DJ Hellfire is offline
Default Copy and Paste Clip Gain issues
Anyone else finding it a major PITA to copy and paste clip gain to the desired location? It's very tricky to get it to paste where you want it.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 03-27-2017, 08:32 AM
briaboy briaboy is offline
Default Re: Copy and Paste Clip Gain issues
YES!
Old 03-27-2017, 09:21 AM
john1192 john1192 is offline
how are you guys doing "it" right now ???
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-27-2017, 10:43 AM
It's a pain in the ass to try to even type out.
1. Select a section of clip gain you want to copy and copy it
2. Put your cursor on the clip you want to paste to at the EXACT position your previous selection starts.
3. Right-click and choose Paste Clip Gain.
For step 2, there are a couple of things to watch out for. First, you have to zoom in really close before you right click to paste. If you don't right click at the EXACT location your selection starts at (even with grid mode on), it won't paste at the exact spot. Also, if the clip you are trying to paste to is trimmed up to the exact spot you are trying to paste at, it won't work. You have to add some blank space on the clip before the position you are trying to paste at.
Ideally I should just be able to highlight a clip, copy clip gain, highlight another clip, paste the clip gain, and be done with it. But this is not the case.
Pro Tools 2021.12
Old 03-27-2017, 11:12 AM
Agreed, very random.
Old 01-24-2018, 08:31 AM
Aquic Aquic is offline
In my case, I can not copy/paste the clip gain from a clip to another how I used to do in ProTools 10. So, that's clearly a bug that Avid need to solve. My only solution at this moment is to convert clip gain to Automation volume, copy that automation volume to another track, and then convert that automation volumen con clip gain again. So f**** boring!
Please, solve this! Clip gain is the only reason I upgraded to ProTools 10, and now it's not working? OMG!
Old 01-24-2018, 08:42 AM
posted in your Thread .. please give system info and it works here just fine .. not sure what is happening to you .. but mayeb these two threads can be combined as they seem to be the same issue ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-24-2018, 09:03 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Hey bro, thanks for the workaround. You must agree with me though, that cut and paste should do exactly that, without long workarounds. Clip gain cut and paste simply does not work. There was an earlier version of 12 (I've forgotten which one) that had clip gain working as expected, after many complaints. But it (as at v 12.8.1 for me) doesn't work! Same old Avid BS all over again and again! But I don't know which version you are currently using...
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 01-24-2018, 09:24 AM
Hiya,
sorry I'm new in the forum. It's supposed that I add my system details in my registration, but now I see that they are not visible. Any idea why they are not visible?
At any case, I'm completely updated as my system (computer included) is new, so my versions are:
Mac Pro 3,5 Ghz 6-Core Intel Xeon E5. 64 GB 1866 Mhz DDR3.
High Sierra 10.13.2
ProTools 12.8.3
Old 01-24-2018, 09:29 AM
Hiya,
High Sierra 10.13.2
ProTools 12.8.3
you can put your info in the Signature under User CP !!
not sure why not working for you yet !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
copy paste clip gain Cryos Pro Tools 12 0 03-13-2016 06:39 PM
shortcut to move a clip vertically without copy and paste cmbourget Pro Tools 12 14 05-08-2015 09:39 AM
Clip gain copy/paste bug yop22 Pro Tools 10 6 02-21-2013 07:22 AM
copy-paste clip and automation data marcelkavka Pro Tools 10 2 08-13-2012 04:20 AM
Copy/paste automation data: Volume to Trim Gain?? el biciclista Pro Tools TDM Systems (Mac) 3 11-22-2006 08:50 PM
